  4. VBA, . NET & IRX
example of GetDistance
  4. VBA, . NET & IRX
GUILLERMO_ZELAYA
GUILLERMO_ZELAYA
Sun Oct 20, 2019 8:08 pm
#1 by GUILLERMO_ZELAYA
I am trying to use the function Getdistance, just like i have used in AutocAD, but using it with Intellicad it doesn't work.
can somebody give the correct way to use the getdistance function?
  • Sat Mar 28, 2020 9:43 pm
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: example of GetDistance
#2 by QuanNguyen
Please refer a sample of GetDistance.
Private Sub GetLength()
    Dim PT1 As Point
    Dim dist As Double
    Set PT1 = IntelliCAD.ActiveDocument.Utility.GetPoint(, "Pick a point:")
    dist = IntelliCAD.ActiveDocument.Utility.GetDistance(PT1, vbCr & "Pick next point:")
    MsgBox (dist)
  • Sat Mar 28, 2020 10:58 pm
GUILLERMO_ZELAYA
GUILLERMO_ZELAYA
#3 by GUILLERMO_ZELAYA
thanks
  • Mon Mar 30, 2020 6:39 pm
Return to “VBA, . NET & IRX”
Re: jig acquire / prompt getP…
This is an interesting issue, especially since AcquirePoint() works visually with the rubber band but still doesn’t trig
merlekey, Wed Aug 12, 2026 4:04 am
Re: Purchasing 14.1 PE Plus Q…
The USB dongle option is useful for anyone who prefers a dedicated hardware license instead of managing everything digit
avan, Mon Aug 03, 2026 1:41 am
Re: Dynamic Block Look Up
Absolutely, you're on the right track—and yes, you can use the Lookup parameter in dynamic blocks to show and hid
recallvalid, Wed Jul 22, 2026 8:37 pm
Re: How to Create, Edit, and …
This is really handy. I’ve always found it a bit of a pain keeping custom textures organized, so having them saved in ar
ashegwen, Wed Jul 22, 2026 3:50 am
  • It is currently Wed Aug 26, 2026 2:28 pm
