Points collection problem in ver 6.4?
The following works ok in 6.2, but gives "Run Time Error 5, Invalid procedure call or argument" in 6.4 at the ElemPoints.Add command. Any thoughts?
Thanks,
Erik
Sub testPoints()
Dim ElemPoints As IntelliCAD.Points
Set ElemPoints = New IntelliCAD.Points
ElemPoints.RemoveAll
ElemPoints.Add 1, 2, 3
ENSIGN,
The points objects are a required argument for the ApplyHatch method.
I tried a collection of points to no avail.
You could try the Function EvaluateLispExpression and use these with the new events "BeginLisp" and "EndLisp" as a work-around until the points class is fixed.
