The following works ok in 6.2, but gives "Run Time Error 5, Invalid procedure call or argument" in 6.4 at the ElemPoints.Add command. Any thoughts?
Thanks,
Erik
Sub testPoints()
Dim ElemPoints As IntelliCAD.Points
Set ElemPoints = New IntelliCAD.Points
ElemPoints.RemoveAll
ElemPoints.Add 1, 2, 3
Points Collection
#3HI, I am also having this problem as i use a points collection for drawing a hatch pattern . Is there any other way of doing a hatch pattern without using the points collection
evaluatelispexpressin
#5thanks john,
unfortunately i dont know lisp programming, would it be possible for you to post some example coding on how to place a hatch pattern using the EvaluateLispExpression routine.
