Dimensioning error
I design sometimes in 1/87 (HO) scale. I started a new drawing today that is 52 scale feet long. If I go from one end of the drawing to the other the readout at the bottom of the screen reads 52'. When I dimension the drawing it says the length is 13' and the other dimensions on it are just as out of scale. What have I done wrong. I think one of my variables is set wrong, but I can't seem to figure out which one. Any help would be greatly appreciated. I am using IntelliCAD 2001.
[This message has been edited by tbeno2003 (edited 12-28-2003).]
Check DIMLFAC system variable. Or type DDIM, chose Units tab and see linear dimensioning scale factor.
If that factor is not 1,00, you found the problem.
Another possibility: Are you dimensioning in paperspace? Turn on TILEMODE to be sure to work in Modelspace.
Michael
