  4. New User
Serialnumber of IntelliCAD
Moderators: CMS Inc, avaernes
  4. New User
Claus D. Mueller
Claus D. Mueller
Thu Nov 28, 2002 12:01 am
Usingen , Germany
#1 by Claus D. Mueller
Is there, like the _PKSER in AutoCAD
something to get the Serial-Number of IC??
Have a nice day!
Claus
  • Thu Nov 28, 2002 11:41 am
avaernes
avaernes
Wed Oct 04, 2000 11:01 pm
Oslo, Norway
#2 by avaernes
There is no common location for the serial number for various distributions of Intellicad. The number is stored somewhere in the registry.
  • Fri Nov 29, 2002 1:43 am
Return to “New User”
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 7:56 pm
