I have had problems in this area with AutoCAD as well, but was able to use a workaround with a script file. Anyone know if this is possible with IntelliCAD?
Thnx
Cheryl
The project I am on deals with zooming in on a certain location, switching to paper space and inserting a block for format purposes, then switching back to model space, and depending on the user either doing a print preview or printing the drawing. I have Pro4 and viewctr and zoomextents are giving me trouble not to mention that everything locks up when in print preview. If anyone can help it would be greatly appreciated. I can't get the examples to display in help even with an updated browser.
Cheryl,
I tried out the PlotManager and had some problems with the Print Object, so I just used the RunCommand Method to Print. I think the code below is what you are looking for - it may point you in the right direction.
Option Explicit
Sub TestPrinting()
Dim intMsg As Integer
' Goto ModelSpace
ThisDocument.ActiveSpace = vicModelSpace
' Using the Help in IntelliCAD and correcting it for errors
ZoomWindow_Example
' Goto PaperSpace
ThisDocument.ActiveSpace = vicPaperSpace
' Insert Your InsertBlock Code Here
MsgBox "See I'm Now in PaperSpace", vbInformation, "PaperSpace"
'---- Your Block Stuff Here ----
' Go back to ModelSpace
' Setup the printing options
' Select a window area
IntelliCAD.PlotManager.Area = Window
' Set the Plot Window Area
IntelliCAD.PlotManager.SetWindow 0, 0, 10, 10
' Print/PrintPreview Options
intMsg = MsgBox("Do You Want To Preview", vbYesNoCancel, "Printing NOW")
Select Case intMsg
Case 6
IntelliCAD.PlotManager.Preview
Case 7
IntelliCAD.RunCommand "QPRINT"
End Select
Sub ZoomWindow_Example()
' This example creates a line and adds it to the drawing using the AddLine
' method. It then uses the ZoomWindow method to zoom in on a window.
Dim myDoc As IntelliCAD.Document
Dim myLine As IntelliCAD.Line
Dim myStartPt As IntelliCAD.Point
Dim myEndPt As IntelliCAD.Point
Dim PtLL As IntelliCAD.Point
Dim PtUR As IntelliCAD.Point
Set myDoc = Application.ActiveDocument
Set myLine = myDoc.ModelSpace.AddLine(Library.CreatePoint(0, 0), Library.CreatePoint(10, 10))
Set PtLL = Library.CreatePoint(0, 0, 0)
Set PtUR = Library.CreatePoint(10, 10, 0)
myLine.Update
ThisDocument.ActiveViewport.ZoomWindow PtLL, PtUR
[This message has been edited by John Finlay (edited 05-03-2003).]
Option Explicit
Sub TestPrinting()
' Goto ModelSpace
ZoomWindow_Example
' Goto PaperSpace
Select Case intMsg
Case 6
Case 7
End Select
myLine.Update
