  4. VBA, . NET & IRX
New Release is now available.
  4. VBA, . NET & IRX
1 post
MTriche
MTriche
Sun Jul 30, 2000 11:01 pm
#1 by MTriche
The new release is now available. I find that many of the previous problems have been corrected. The text is now working with .shx files and the plot is now plotting to the fullest extent of the paper.
Melodie
  • Thu Aug 08, 2002 2:46 pm
1 post
Return to “VBA, . NET & IRX”
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 7:36 am
