These questions were made in the Spanish forum, but VBA is out of my knowledge, so if anyone can answer please, then I'll translate to Spanish, thanks in advance...
1) "How I can associate the execution of a macro in VBA to an option of menu '. It is to say: I want that when selecting a menu option, executes one of my macros. I have tried it with DefineFunction, and when it is executed, it executes the VBA. function Later, if attempt to execute it from the line of commandos in the form (macro name) does not do anything, or, if the function gives back a value, it leaves the program directly."
2)"User forms: I must show a dialogue in my application. I do it with VBA, to have more control on events... but it does not let to me modify the size of the form. So that '. "
Well, thank you very much
Alberto,
Item 1
To execute a macro from a toolbar or a menu use:
^C^C^C(command "-vbarun" "ModuleName.MacroName")
Notice the "-" sign in front of the vbarun.
If you want to repeat the command use:
^C^C^C(defun C:AnyName(command "-vbarun" "ModuleName.MacroName"));AnyName
This defines the menu item as a command and you can right click your mouse button or press enter to repeat the macro.
Item 2
Do you want to control the form size at run time or design time?
Item 1
Item 2
Yolanda,
It's the same method.
Open a new drawing.
Open VBA IDE
Insert a new UserForm (default UserForm1)
Insert two command buttons named cmdDouble and cmdHalf
Double click on a command button.
copy and paste code below in UserForm1 module:-
Option Explicit
Private Sub cmdDouble_Click()
UserForm1.Height = UserForm1.Height * 2
UserForm1.Width = UserForm1.Width * 2
MsgBox "The UserForm1 Height =" & UserForm1.Height _
& vbCr & "The UserForm1 Width =" & UserForm1.Width
Private Sub cmdHalf_Click()
UserForm1.Height = UserForm1.Height / 2
UserForm1.Width = UserForm1.Width / 2
Now run the Form and see how it doubles when you click the Double command button and it halfs when you select the Half command button.
Open a new drawing.
Open VBA IDE
Option Explicit
Yolanda,
Another method is to add the following to a form, it will make the lower right hand corner of the form a hot spot which can be dragged with the mouse to resize.
'Begin Code
Private Declare Function ReleaseCapture Lib "user32" () As Long
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long
Private Const WM_NCLBUTTONDOWN = &HA1
Private Const HTBOTTOMRIGHT = 17
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Private Sub UserForm_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
Dim lngHwnd As Long
If X >= Me.Width - 10 Then
If Y >= Me.Height - 30 Then
lngHwnd = FindWindow(vbNullString, Me.Caption)
ReleaseCapture
SendMessage lngHwnd, WM_NCLBUTTONDOWN, HTBOTTOMRIGHT, ByVal 0&
Private Sub UserForm_MouseMove(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
Me.MousePointer = fmMousePointerSizeNWSE
Else
Me.MousePointer = fmMousePointerDefault
'End code
hope this helps,
Scott
'Begin Code
Dim lngHwnd As Long
ReleaseCapture
Else
'End code
hope this helps,
Scott
