  4. AutoLisp/SDS
How to get variable value?
Moderators: CMS Inc, avaernes
  4. AutoLisp/SDS
jorgematheus
jorgematheus
Sun Apr 24, 2005 11:01 pm
Caracas, Miranda, Venezuela
#1 by jorgematheus
Hi
In autocad i use ! the exclamation sign to know the variable value.
IE:
(setq one (+ 2 3))
! one
-> 5
The only way i have found in Intellicad is with princ
(princ one)
->5
Is there an easy way to do this?
Thank
Jorge Matheus
  • Mon Apr 25, 2005 8:22 am
MROCK
MROCK
Mon Oct 09, 2000 11:01 pm
Rio de Janeiro, RJ, Brazil
#2 by MROCK
In Icad it is the same as in Acad. Use the exclamation mark "!"
Michael
  • Tue Apr 26, 2005 7:39 am
Return to “AutoLisp/SDS”
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 7:19 am
