  4. AutoLisp/SDS
SDS help - linker error with UNMODIFIED lispcmds example
Moderators: CMS Inc, avaernes
  4. AutoLisp/SDS
vladdygo
vladdygo
Thu May 27, 2004 11:01 pm
Bucharest Romania
#1 by vladdygo
Pls somebody help me! I'm not able to build any sds example application provided by the manufacturer. (BricsCad). I use Visual C++ 6.0, and my linker goes nuts...
Linking...
Lispcmds.obj : error LNK2001: unresolved external symbol _sds_exit
and so on...
What should I do?
Thanks!
  • Fri May 28, 2004 4:35 am
led
led
Tue Jul 06, 2004 11:01 pm
#2 by led
only _sds_exit?
  • Wed Jul 07, 2004 1:56 am
led
led
#3 by led
only "_sds_exit" unresolved?
  • Wed Jul 07, 2004 1:57 am
Return to “AutoLisp/SDS”
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 9:20 am
