  4. AutoLisp/SDS
insert multiple blocks from one point
Moderators: CMS Inc, avaernes
  4. AutoLisp/SDS
1 post
georges
georges
Contributor
Mon Mar 03, 2003 12:01 am
#1 by georges
I'm loocking for a lisp routine or a vba code to insert multiple blocks (per angl, distance) using always the same previously selected basepoint. For each inserted block i would like to define the scale (the same value for x, y,z) and no rotation.
Is there anybody who can help me?
  • Sun Mar 09, 2003 1:53 pm
1 post
Return to “AutoLisp/SDS”
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 8:00 am
