Mjsmyth,
I tried out your routine and it appears to work great. While this routine may not mimic zd exactly it sure is better than what we had before. I tried your routine and zepps modified one and had no problem with either one. Thank you for sharing this with us. I know I will use it often. With your permission I would like to post it on this forum also.
Melodie
P.S. Congratulations on receiving EAUG Member of the Month award.
[This message has been edited by MTriche (edited 03-14-2001).]
Melodie,
By all means post it on the forum. I see you must have been looking at the eaug.org site, thatmember of the month award is a bit old now (unless I have won it again somehow) but thank you anyway.
I do have another website, www.thedraftingshop.com and in the downloads area there, you might find other bits and pieces that could be of use.
Michael John
Michael,
I have added a Bonus forum for helpful things such as your lisp routine and link to your site. I have looked at your tutorials in the past and they are some of the best I have seen. I have often times recommended your site to others that have emailed in asking where they could locate tutorials.
Thank you for the contributions,
Melodie
I downloaded the upgrade on Friday 2001.05.04. The new version is ver 2.2.00025.
It fixed approx 15 problems including the UNDO command problem. Unfortunately it still contains some unresolved issues. Obviously no one at Bricsnet is paying any attention to the forums. Diameter symbol still does not work which is beyond me because that should have been a simple programming correction. BY the way, if you don't mind your drawings not being 100% ACAD compatible; Intellicad is 100% MS Windows based. You can use the keystroke ALT+ 0216 for the diameter symbol. Personally I prefer to use the Windows character map keystokes as you have more flexibility such as trademark and registered symbols.
[This message has been edited by FINNBEAR (edited 05-10-2001).]
