I am using the "HPDesignjet 650C (C2859B) by HP" driver to create my plt files that I send to the print shop.
When I click print, I am asked for the name of the file only, not the folder where it should go. Is there a way to change this, in order to allow me to choose the folder?
[This message has been edited by asiebert (edited 03-12-2005).]
Asiebert,
Maybe I don't understand your problem, however, it seems to me that it is just a matter of specifying the folder. For example, if you called your file "job2" and wanted it to plot to your C drive in a folder named "projects", you would type C:\projects\job2 Let me know how you make out. Carl
Thanks, typing the complete path and file name, with the plt extension, works ok. The problem is if you want the plt to go to, for example, C:\work files\client 1\building A\final project\CAD\plot files ... then you would have to type a lot, would be better to have a "browse" button to be able to choose the folder. Anyway, for now I think I will send all my plts to C:\plts (a short path), and later move them to the project folder, after sending them to the print shop.
Thanks again.
Andre
Thanks again.
Andre
