Re: IntelliCAD v13 is out! But is it normal there are not french localisation with it?
#18
Bonjour tout le monde,
Français de Charente en retraite je suis tout nouveau sur ce Forum.
Autrefois utilisateur occasionnel d'AutoCad (en 2D), j'utilisais un logiciel gratuit equivalent.
Devant quitter ce logiciel pour cause de crashes sous Windows11, j'ai installé pour essai la version 13.1 d' IntelliCAD.
Il semble qu'il n'y ait que la langue Anglaise sur la version d'essai, et cela m'est un peu pénible?
IntelliCAD, même dans sa version la moins chère (environ 100$?), me semble une bonne alternative.
Y a-t-il moyen de tester une version Française avant d'investir?
D'avance merci pour votre aide.
#19
Jeep16 wrote: ↑
Wed Jan 21, 2026 7:57 am
Hi Jeep,
Please use the command OPTION, then go to the tab "Display", click on the "..." button to show the "Set Language", here you can see all the languages of the version.
Here's the "Set Language" UI on the 14.1 version.
#21
Hello,
I have been a happy user of CMS Intellicad v14.1 PE (USB key) for a year now.
However, I have noticed for the past few days that a message appears when opening the first drawing:
Unable to load the file or assembly 'System.Runtime, Version=8.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The specified file was not found.
Then I can work on as many files as I want without encountering any other problems.
The message only appeared again after closing and reopening of Intellicad.
Some research suggested to me to install ;.NET Runtime 8.0 by downloading the ASP.NET Core Hosting Bundle
-I executed the dotnet-hosting-8.0.31-win.exe file, but no improvement.
-I then tried to add dotnet-hosting-8.0.0-win.exe without any success.
Would you have an explanation or a suggestion, please?
On the other hand, I am annoyed by the systematic feedback when starting an update notification.
I think my license doesn’t allow me to update or upgrade, which suits me very well.
What can I do to stop this window, since I can’t find any settings for it?
Thank you in advance
