Re: A saving problem
sln8458 wrote: ↑
Mon Nov 11, 2024 1:42 am
Hi
Which version are you running?
Has there been any customisations?
Steve
Hi Steve,
My version is Icad 13 pe+,
and it should not been any customizations.
I just downloaded from Itellicad website and buy the authorize.
thanks for your reply
You're running the same version as me :)
I can't find any option to turn on/off creating a pdf when saving.
My only thought was that your install had been customised to include creating a pdf when using tha save command.
What command are you using to save?
Is it from a toolbar or Ribbon?
Also can you try typing 'save' on the command line and then follow prompts, does that also create a pdf?
Steve
sln8458 wrote: ↑
Tue Nov 12, 2024 4:04 am
Steve
Hi Steve,
I find the option that creating pdf file myself,
it is in options->Print and Publish->Auto Publish
I might check the automatic publish checkbox by accident.
I disabled the checkbox then it would not save any pdf files.
Thanks your reply
verdant wrote: ↑
Tue Nov 12, 2024 1:06 pm
Hi Steve,
Thanks your reply
Well found. :)
Thanks for posting the solution
Steve
Thanks for sharing the solution! I had a similar issue in the past, and I appreciate the detailed steps. Just to clarify, does anyone know if this auto-publish feature is available in other versions as well? I’m curious if it might affect users who are still on older versions.
