Issue - IntelliCAD 13.1 latest update - Unable to snap to all grips in regions or solids
Is anyone else seeing this? If I create a region or a solid from geometry, as soon as I do, I can only snap to some grips. If I say create a square I can snap to all corners. If I turn it into a region I am only able to snap to two corners. If I explode the region I can then snap all corners.. If I then turn it back into a region, I can once again only snap two corners but the two corners I can snap change to a different set of corners!? This happens even if the region is on the XY plane with no Z co-rdinate. I've tried everything with no success. Recently installed the update available but it did it on the first 13.1 and this one as as well.
thanks
