BIM - RFA files
Anyone with experience in attching RFA files and accessing the contents??
I have attched a RFA file from a suppliers website, yet when attached (via TOOLS > BIM UNDERLAY) all I manage to get is a single block.
No table is loaded/displayed, yet there is a TXT file with the RFA in the search path.
Re: BIM - RFA files
Hi Steve,
How are you ?
I mean you make a mistake, you must use Insert > RVT underlay...
A RFA file is a Autodesk Revit Architecture file, a Revit Family no?
Could you share this file please ?
Example: Coffret C100P100.rfa
Then your resource is manageable by the REFs EXPLORER :
Re: BIM - RFA files
Hi Pat, I'm well :) & you?
Look here:
https://www.stelrad.com/trade/bim-information/
You should download the zip file, inside is an RFA file & TXT file. Put these into a folder in the search paths
Or as in my case make and add a new one.
Open a new dwg, then from the dropdown, Insert/BIM Underlay/Bim underlay..... goto the folder with the zip/RFA file and select the RFA file.
The TXT file is a Catalogue of all that is in the RFA (see the 2 pdf files in the zip)
60+ items in the RFA, but I can only achieve 1 ..????????
Sent a feedback form & currently in discussion with Support @ ITC.
Re: BIM - RFA files
Yes there is a radiator :
But is it possible to have a parametric object like in REVIT, I don't know???
My thought : this txt file must be in excel format to be associated to the shape....I will search...
EDIT : Steve I tranformed the .txt in .xsl and attached it to the drawing but nothing.
This .txt is for parametric data to REVIT and don't work with IntelliCAD.
Re: BIM - RFA files
Hi Pat,
Yes you are probably correct,
but there is no explanation in the HELP files as to what the user should expect when attaching an RFA file.
So I wait for the ITC support to get back to me.
My view is that having a RFA Underlay is worthless without the contents of the family/catalogue.
PS, I also created an XLS file, copied it to the ITC support along with ALL I posted above + more :)
Re: BIM - RFA files
From ITC support:
The ability to embed multiple components into one RFA is a feature that the current version of IntelliCAD does not support.
This is poor in my opinion, why have the ability to attached an RFA Underlay, but NOT access it's contents??
Re: BIM - RFA files
Look here in the properties panel :
A lot of values are not changeable !!! Because we are not in REVIT but this parametric values are there !
EDIT: I have learned that in REVIT there are System parameters and Shared parameters and etc...
System parameters are these parameters inactifs in IntelliCAD.
The .txt file is a shared parameters. In REVIT these values ared in a table and each column are used to change the shape of your radiator, not as parametric model but simply with custom parameters .
If you have a concrete post with d section et h hight, you create a custom parameter to d weight (or H) and connect it with a shared parameter. In the shared parameters editor, you select your model and D + H are actived and transfered to your drawing with these shared parameters.
https://www.youtube.com/watch?v=V_YQvEbjxeo
