  4. AutoLisp/SDS
LISP error: too few arguments
Moderators: CMS Inc, avaernes
  4. AutoLisp/SDS
Roberto felix
Roberto felix
Mon Apr 07, 2025 5:35 am
#1 by Roberto felix
Hi! why I have been getting continuously the error "error: too few arguments" when all seems good with parameters?
  • Mon Apr 07, 2025 5:40 am
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: LISP error: too few arguments
#2 by QuanNguyen
Hi Roberto,
Please check if you have a function of the same name defined elsewhere with more arguments.
  • Tue Apr 08, 2025 2:29 am
Return to “AutoLisp/SDS”
Artisan with cms 15
  • It is currently Sat Oct 10, 2026 11:39 pm
