Why don't use :
1 - a polyline of oblong hole
2 - extrude it then in 3D object?
or
2 transform it in surface
and
3 - extrude it then in 3D object.
EDIT ; I tested with 2 cubes > addition 3D object work
but substraction 3D object don't work !
Here is the function ^C^C^C_subtract don't work
I have this traceback: Modeler operation error: At least two coplanar solid bodies, surfaces, or regions must be selected
but I use 2 3D cubes only !!!!
But I use two 3d onject : cubes !!!!
_intersect work fine but
_subtract don't work !!!
FMintersection work but
FMsubstraction don't work
HERE is a video of the substraction operation :
https://www.dropbox.com/scl/fi/o9ova7xq ... 2t5in&dl=0
HAAAA OKKKK I understand NOW you must select the substraction operation, then click on the first object + enter and then select the object you want substract ! EUREKA
- 2025-03-31 10 20 06.png (10.59 KiB) Viewed 98362 times
- 2025-03-31 10 26 57.png (5.76 KiB) Viewed 98358 times
