pt145jms wrote: ↑Wed Mar 19, 2025 3:34 pm
Thank you for the replies. This had me pulling my hair out. I'll patiently await the fix. Thank you for the work around Quan. I thought I tried this before reverting versions and didn't get the same result. It would display a new scale in properties but not affect the viewport.
I understand the frustration, as this issue seems to have affected multiple users after the February 27th update. It’s good to see that some of you have found a workaround using the Properties Palette, as noted by QuanNguyen. Hopefully, CMS is aware of this and will be working on a fix soon. For those experiencing the same issue, it may help to continue using this workaround for the time being.
For those who are still struggling with the issue, it might be worth trying the following steps:
Ensure the viewport is unlocked.
Try adjusting the scale via
poki action games Properties Palette as suggested.
Double-check that all other settings in the annotation scales are set correctly.
It seems like CMS should offer the previous version as a temporary option until the fix is rolled out, but for now, let’s hope they resolve it quickly. If you haven’t already, I’d recommend contacting CMS support directly to report your issue for quicker resolution.
Thanks to everyone for your input and patience. Let’s stay hopeful that a fix is on the way soon!
