SLICE command - SOLVED!
Hello everybody again!
I have a question regarding SLICE with SURFACE command.
As I have learnt, Surface has to be extruded throughout EXTRUDE-MODE-SURFACE. And as such, SLICE works with spline:
SLICE command 01 Layout1a.jpg (219.58 KiB) Viewed 10921 times
My question is: How to make a surface out of PLINE, that would CORRECTLY slice 3DSOLID?
Many regards,
Aleksandra
Graduate Engineer of Architecture, Belgrade, Serbia
Aleksandra Popović, Graduate Engineer of Architecture, www.rise.co.rs
SLICE command 01.zip
(35.01 KiB) Downloaded 268 times
Re: SLICE command
I've found it a little clunky as well to be honest. I figured I could import a surface and use that, sometime it cut other times it tried to rectangle select instead of selecting my surface. It may be something to do with the surface type.
The way I've done it is to use project curve so I've drawn in a spline, project that to the body and you get an outline of curves. Then build a surface using netwrok curves. Then it slices ok.
I'm not sure how you would use a totally organic surface in this sense if you need to rebuild it, maybe there is a sequence inside intellicad for making it the right type of surface that work with the command
(43.34 KiB) Downloaded 275 times
Re: SLICE command
Hello Ugmentalcase!
Thank you for reply!!! I figured out it has to do with surface type. To be honest, I wrote to software developers. I think they are checking this as well, because it is obviously some kind of a bug.
Nevertheless, I need a workaround until they fix it.
I am not sure if I understood what you wrote... You managed to slice 3DSOLID by projecting a spline, am I right?
Well, I guess SLICE command somehow works with more complicated surfaces, such as curves; however it does not work with straight lines!!!
Do you know how can I slice with green surface (made out of PLINE), as shown on the picture below:
SLICE PLINE.jpg (14.23 KiB) Viewed 10856 times
Many regards,
Aleksandra
Re: SLICE command
Yes, so I drew the spline on the top of that end piece, used project curve from the tool bar and it gave me 4 curves on the solid block. The spline shape on the top and bottom faces and then two straight lines down the sides. Then I used network surface, select top and bottom curve, right click, select side curves, right click and it make the surface.
The used slice command, picked the solid, picked 'surface' from the command bar at the bottom of the screen, then picked the surface and it sliced it.
It was only the other day I was trying to slice a solid as I was working on making some dynamic section line blocks, so I wanted to be able to slice a solid to then use flatshot and make a section view. Couldn't get it working, then saw your post and tried some other things :-)
Re: SLICE command
Hi Aleksandra,
I tried some tests but nothing for you :
2025-02-04 16 58 53.png (11.53 KiB) Viewed 10847 times
When I use an extruded polyline, just the first plane is use to slice/ trim the volume.
But with a surface extruded, no problem with subtraction of volume to cut the volume!
Weird ! Why a polyline can cut ? Just a extruded spline????
Re: SLICE command
Hi Patrick!
You are an angel!
How did you manage to slice with SUBTRACT command?
I tried to make a SURFACE (with Extrude-Mode-Solid) command and than SUBTRACT, but it did not work.
I also tried with SURFACE (Extrude-Mode-Surface) command and than SUBTRACT, but it also did not work.
If I make two solids and SUBTRACT, it works normally. It cuts a part of my first solid and that's it.
But that is not what I need. I need SLICE command to work as it should. Nothing for me :(
Re: SLICE command
SLICE works on the latest v13.1 build.
If the slicing plane is generated from a PLINE extrusion, then such plane is created using the EXTRUDE command.
run SLICE > Pick solid to section > click "S" and select the Surface (the slicing plane) > press enter to keep both sides of the sliced solid.
