Limit tolerance not functioning
When using limit style tolerance on dimensions, the value changes are not applied. As seen in the image, the space is allocated for the bottom value, but the value is not shown. The top value has the upper limit amount applied. For this example, the lower limit value should be 86.16 [3.392]. This issue does not occur when using deviation style.
I need to know if this is a bug or an installation issue. Build: 11.1.435.145443.PE+.VC16.x64.CMS111. OS: Windows 11 Home, version 10.0.22632 Build 22631.
Broken limit tolerance.png (28.39 KiB) Viewed 7623 times
Re: Limit tolerance not functioning
Although the space for the lower limit value is allotted, it appears that you are having trouble with it when you apply limit style tolerance in your dimensioning system. The system may be anticipating a particular format or arrangement for the lower and upper numbers in limit style. The software may not display the lower limit appropriately if it is too tiny or too large.
Please PM me for more information geometry dash@cironex.com
