asia,
As I understand the Find command just finds text or mtext in a drawing.
Is that what you are looking for?
John Finlay wrote:asia,
John,
Yes, find command looks for a certain text in a set of drawings (like in an a steel erection plan),then after finding the text, the drawing zooms on the target where it is placed on the middle of the screen.
You can then replace that particular text or all the same text in a single command.
Thanks,
asia
Re: FIND command
es, IntelliCAD has a command similar to AutoCAD's FIND command for searching text. In IntelliCAD, you can use the FIND function to locate and replace text within a drawing, making it easier to search for specific annotations or marks on a large plan. To use it, go to the Edit menu, select Find and Replace, then enter the text you're looking for. This can help you quickly locate elements without having to manually scroll through the drawing.
