Re: AEC layers
To prevent AEC layers and cantilever/overhangs from auto-inserting when you create a wall, you can adjust your wall style settings. In your design software, look for the wall properties or styles menu. Here, you can either disable the automatic cantilever/overhang options or select a basic wall type that doesn’t include those features. Additionally, check your template settings; it might be helpful to create or modify a template without these features for future projects. This way, you’ll have more control over your wall configurations from the start.ragdoll hit
Re: AEC layers
kidforestay wrote: ↑
Thu Oct 17, 2024 8:25 pm
Can you elaberate, where can these settings be found in Icad software?
Re: AEC layers
This occurs even when using a wall style that I created from scratch. There are no apparent setting or option to disable this feature. >:( Thank you for trying to help though. I guess it's easy enough to turn off the "cantilever" and "overhang" layers, but every other imaginable AEC layer is thrown in as well and cluttering up the Layer manager.
