Re: Extended Screen Problem
doukan wrote:
Thu Apr 25, 2024 2:21 am
Hi, When I connected an external monitor to my laptop intellicad doesn't work. Not opening any file. Could you help me?
Hi there,
It sounds like there might be an issue with your display settings when using an external monitor. First, ensure that your graphics drivers are up to date. Next, try adjusting the display settings: go to your laptop's display settings and make sure the external monitor is set to "Extend" rather than "Duplicate" or "Second screen only." If IntelliCAD still doesn't open files, try launching it in compatibility mode: right-click the IntelliCAD icon, go to Properties > Compatibility, and select an older version of Windows to run the program. Restart your laptop and see if this resolves the issue. If the problem persists, consider reaching out to IntelliCAD support for further assistance.
level devil
One common reason is that the display settings might not be configured correctly for the external monitor. Try going into your computer's display settings and make sure that the external monitor is set as the primary display or that Intellicad is configured to open on the correct screen. Another potential issue could be related to the graphics driver. I recommend checking to see if your graphics driver is up to date. Updatingstrands game the driver can often resolve compatibility issues with external monitors.
