Hi all,
I've done very little with dynamic blocks, but made a few for adjusting stock sizes of parts I have.
I've been trying to expand that by looking at making a dynamic block to change shapes, for example a welding call out. Fillet, bevel and so on.
I've succesfully made one but it was lengthy and found that I may be able to use 'lookup' instead. Watching over some tutorials (granted for autocad) I'm not sure it's possible. They seem to right click the lookup parameter and make it a 'double lookup' which isn't a option for us here.
So I'm basically after some help/guidance. It it possible to use lookup to show and hide various shapes?
Thanks in advance
Re: Dynamic Block Look Up
#2Yes, it's definitely possible to use lookups to show and hide various shapes within a dynamic block in AutoCAD.
Here's a general approach:
Create Basic Shapes: Start by creating the different shapes you want to display (e.g., fillet, bevel, etc.) as individual blocks.
Create Dynamic Block: Create a new dynamic block and add these individual shapes as block references.
Create Lookup Parameters: Create lookup parameters that will control which shape is visible. For example, you could create a lookup parameter called "Type" with values like "Fillet," "Bevel," and "None." space waves
Assign Visibility Conditions: Use visibility conditions to associate each shape with the corresponding lookup parameter value. This will ensure that the correct shape is displayed based on the selected lookup value.
#3Thanks for the reply. I must be doing something wrong. It's the last stage I just can't get my head round it!
