Linework not appearing must regen space everytime.
philiplemons
philiplemons
Sat May 30, 2020 10:36 am
#1 by philiplemons
Currently on the trial looking for a home cad alternative. Must I regen after drawing a line or polyline every time or is this a glitch in the software! Thank you!
  • Sat May 30, 2020 10:40 am
philiplemons
philiplemons
Re: Linework not appearing must regen space everytime.
#2 by philiplemons
Also after every command such as deleting in order to update the model space I have to constantly regen,
  • Sat May 30, 2020 10:44 am
DenisSilveira
DenisSilveira
Sun May 24, 2020 8:22 am
#3 by DenisSilveira
Same operation ...
  • Sun May 31, 2020 2:25 pm
tedeli9322
tedeli9322
Tue Apr 16, 2024 3:40 am
#4 by tedeli9322
It sounds like there might be a glitch in the software if the linework is not appearing. You shouldn't have to regen every time after drawing a line or polyline.
viewforum.php?f=26&sid=e458a60922dc136a8360c6074036de46my location now
  • Tue Apr 16, 2024 3:45 am
tedeli9322
tedeli9322
#5 by tedeli9322
I recommend reaching out to the software support team for assistance in troubleshooting this issue.
  • Wed Sep 11, 2024 1:25 am
Rania
Rania
Wed Sep 18, 2024 3:09 am
#6 by Rania
You shouldn’t need to regenerate after every line; check your settings and consider reaching out to support if the issue persists.
https://www.chirurgiaevacanze.it/
  • Wed Sep 18, 2024 3:18 am
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 3:03 am
