The GetPoint method will not stick to anything if you provide a "relative" point argument for rubber banding.
eg: GetPoint(varPoint1, "Pick Next Point")
Is there a workaround? Will the GetPoint method ever be fixed? It seems to be broken in every version of ICADtime calculator.
Re: The GetPoint
#2Hi,
Which language do you use?
AutoLISP, VBA or .NET
Here's the simple line using AutoLISP.
(setq pt1 (getpoint "\nFirst point:"))
(setq pt2 (getpoint pt1 "\nNext point:"))
