USB Dongle Maker - CMS IntelliCAD 13.0 PE Plus
reddog777
reddog777
Thu Nov 30, 2023 5:51 pm
#1 by reddog777
I do not see an option to purchase the USB dongle maker for the new version.
Will the 12 version of the dongle maker work with 13 ?
  • Wed Sep 04, 2024 1:38 pm
AhmedNicolas
AhmedNicolas
Wed Oct 09, 2024 1:13 am
Re: USB Dongle Maker - CMS IntelliCAD 13.0 PE Plus
#2 by AhmedNicolas
reddog777 wrote: ↑
I do not see an option to purchase the USB dongle maker for the new version. fall guys
You should wait a while for the product to be released sooner!
  • Wed Oct 09, 2024 1:17 am
UGMENTALCASE
UGMENTALCASE
Wed Mar 29, 2023 2:40 pm
#3 by UGMENTALCASE
Its available now. I asked at the time and it wasn't ready, a few weeks after release and it is now on the website
  • Tue Oct 15, 2024 12:18 am
holacuna
holacuna
Tue Oct 29, 2024 12:38 am
#4 by holacuna
To determine that, I think it's bestgoogle baseball to check the official documentation or support resources for USB Dongle Maker you're referring to. But in general, compatibility can vary between versions.
  • Tue Oct 29, 2024 12:48 am
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 2:52 am
