UCS View changes
I need some help for the view command,
We work in different UCS to plot the data with multiple views.
When I go for one view from the two views, the drawing rotates to as per WCS even when I select the Both ucs to same.
How can I fix it. I don’t want the drawing to rotate with change of UCS and keep one view.
Can you please help on this?
Re: UCS View changes
Save Your Views: To avoid rotation issues, you can save your current view settings. In AutoCAD, you can use the VIEW command to save and restore views. Follow these steps:
Type VIEW in the command line and press Enter.
In the View Manager dialog, click New to create a new view.
Set up your view as needed and click OK to save it.
Use Named Views: Once you’ve saved a view, you can easily restore it by using the VIEW command again and selecting your saved view from the list. This way, no matter how you change the UCS, your view will remain consistent.
Save UCS and View Together:
To ensure that the view and UCS are linked, you can use the UCS command to define a new UCS and then use the VIEW command to save a view relative to that UCS. When switching UCSs, the saved view will maintain its orientation based on the UCS it was saved with.
snow rider
Align the UCS: Before changing the UCS, ensure that the UCS is aligned with the view using the UCS command, followed by View.
Use Plan Command: After setting the UCS, use the PLAN command to adjust the view to match the current UCS without rotation. This command aligns the view direction with the UCSslope
Named Views: Save your desired view with the correct UCS settings using the VIEW command and then recall it when needed. This helps to preserve the view orientation.
