Quick Access Toolbar modification
I found that it is not possible to add drop-down lists to the standard quick access toolbar by using the option "customize UI..."
I tried to add the color drop-down list by editing the file "Default.cui" as follows, but nothing significant happened...
Is there any suggestion?
<QuickAccessToolbar UID="ITC_QAT_TOOLBAR1" Visible="true">
<ModifiedRev MinorVersion="330" UserVersion="17"/>
<Name ID="30205">Quick Access Toolbar</Name>
<QuickAccessToolbarStandardItem MenuMacroID="qnew" UID="ID_QAT_New"/>
<QuickAccessToolbarStandardItem MenuMacroID="open" UID="ID_QAT_Open"/>
<QuickAccessToolbarStandardItem MenuMacroID="save" UID="ID_QAT_Save"/>
<QuickAccessToolbarStandardItem MenuMacroID="saveas" UID="ID_QAT_SaveAs"/>
<QuickAccessToolbarStandardItem MenuMacroID="print" UID="ID_QAT_Print"/>
<QuickAccessToolbarControl UID="rbnctrl-undo">
<GreyedOutExpression>HASUNDO=0</GreyedOutExpression>
</QuickAccessToolbarControl>
<QuickAccessToolbarControl UID="rbnctrl-redo">
<GreyedOutExpression>HASREDO=0</GreyedOutExpression>
<QuickAccessToolbarControl UID="rbnctrl-workspace"/>
<QuickAccessToolbarControl UID="rbnctrl-layer-qat"/>
<QuickAccessToolbarControl UID="rbnctrl-color-qat"/>
<QuickAccessToolbarStandardItem MenuMacroID="layercontrolfilter" UID="ID_QAT_LayerControlFilter"/>
<QuickAccessToolbarStandardItem MenuMacroID="erase" UID="ID_QAT_Delete" Visible="false"/>
<QuickAccessToolbarStandardItem MenuMacroID="help" UID="ID_QAT_Help" Visible="false"/>
</QuickAccessToolbar>
Re: Quick Access Toolbar modification
Hi apa,
Question 1 : What is this drop-down menu <QuickAccessToolbarControl UID="rbnctrl-color-qat"/>
Is it this menu?
Question 2 : Do you try to use only the palette Tools > Customize the use UI ? Instead of opening the .cui file!
Patrick
EDIT:
Your choice of rbnctrl-color-qat don't work for me : I mean this is a macro menu.
I tried this ; The "Select the color" menu ?
Thank you very much!
I added the "Select the color" button and it works, however, I am accustomed to the dropdown list. Moreover, I would also like to add "rbnctrl-linetype" and "rbnctrl-lineweight"...
"rbnctrl-color", "rbnctrl-linetype" and "rbnctrl-linetype" are ribon items, and I thought I could make them inhabit the quick access toolbar the same way "rbnctrl-layer" does...
A2Q1:
The drop-down menu "rbnctrl-color" is this:
Beneath it are the "rbnctrl-linetype" and "rbnctrl-lineweight" dropdown lists.
A2Q2:
I tried to use "Customize UI" but theese entities (as well as "rbnctrl-color", "rbnctrl-linetype" and "rbnctrl-lineweight") are not editable via the "Customize UI" dialog box:
