Good morning!
Yes, DWG files are compatible with the "Import > Link AutoCAD" function in Autodesk 3ds Max. You can link a DWG file into a 3ds Max scene by going to **File > Import > Link AutoCAD**. This allows you to maintain a "live" link between AutoCAD and 3ds Max, so any changes made to the DWG file will automatically update in 3ds Max Files - Autodesk Knowledge Network](
https://help.autodesk.com/cloudhelp/202 ... 3BF6E9.htm).
[/quote]
Hi, thank you for your reply. In the meantime, I checked the compatibility with 3dsmax, and everything works fine with the dwg link. Intellicad has the same "display resolution" parameters as Autocad.
