How to display current layout
akg1963
akg1963
Tue Feb 28, 2023 3:54 pm
#1 by akg1963
I'm new to Intellicad. I'd like to set this up exactly like autocad LT. I have not found a way to display the current layer I am on. Is there a way to show the current layer?
  • Wed Mar 01, 2023 7:49 am
sln8458
Mon May 19, 2003 11:01 pm
Re: How to display current layout
#2 by sln8458
Turn ON the 'Enterty Properties' tool bar.
  • Wed Mar 01, 2023 8:02 am
akg1963
akg1963
#3 by akg1963
That did it. Thank you.
  • Wed Mar 01, 2023 8:46 am
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 8:40 am
