  4. AutoLisp/SDS
ssget to select blocks with attributes
Moderators: CMS Inc, avaernes
  4. AutoLisp/SDS
caddhelp
caddhelp
Fri Feb 03, 2023 5:34 pm
#1 by caddhelp
filter 66 doesn't work for some reason.
(command "ERASE"(ssget "x" '((0 . "INSERT")(66 . 1))) "")
is it a bug?
  • Fri Feb 03, 2023 5:45 pm
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: ssget to select blocks with attributes
#2 by QuanNguyen
well, it didn't work for unknown reasons.
Try this to filter blocks with attributes:
(command "ERASE" (ssget "x" (list '(-4 . "<AND") '(0 . "INSERT") '(66 . 1) '(-4 . "AND>") )) "")
  • Tue Mar 12, 2024 8:28 pm
rob.7913
rob.7913
Contributor
Thu Mar 28, 2024 2:51 pm
#3 by rob.7913
Did that work? Curious...I will be using that on the regular if it does.
  • Sat Mar 30, 2024 8:15 am
Return to “AutoLisp/SDS”
If you&#039;re a v15 licensed user then you&#039;ll get it available at the next v15 maintenance build. It&#039;s curre
latest version PE15.0 for ms here. Program says: &quot;Unable to recognize command &quot;Hsketch&quot;. Please try ag
  • It is currently Thu Nov 26, 2026 10:43 am
