Has anyone had any success here??
I have a number of drawings with TIF files attached, when printed the CAD file prints fine with a large black box where the TIF file should be??
The tif files print fine individually using paint shop pro 8, also windows imaging.
Need help, new contract requires this functionality.
Sorry, should have said
The file(s) print fine to my epson 1270, the problem is when I print to PDF995, this is a print driver that creates pdf files. I have updated drivers, their tech' support have tried numerous adjustments..... all to no avail.
I can print this config of dwg/tif thro a colleges copy of Autocad to PDF995 with NO problems. If it were only a couple of drawings then I would follow this route, but the contract is for 100+ drawings (the actual no. of drawings could end up at over 500 if I can meet the deadline)
I suppose the image format has to be tif, otherwise I would suggest .png. You could try a different pdf printer, Pdfcreator:
https://sourceforge.net/project/showfil ... p_id=57796
There's both a 0.7.1 and a beta 0.8 version available.
Icad ver 4PE, downloaded the latest up-date but not yet installed. Running on win98 256k ram
Tried different TIF formats, group 3 & group 4 fax. The tech support at PDF995 have tried a number of different drivers but with no success. If I save as Autocad R14, and open in R14 I can print the same dwg/tif files to PDF995 perfectly, simillarly with Microstation SE. It's only Icad that drops the ball!!!!
avaernes,
Thanx for the alternative, I tried 3 or 4 others over the weekend which all failed I'll try this one later this week....away for a couple of days.
[This message has been edited by sln8458 (edited 01-26-2004).]
avaernes,
