Trapezoid area lisp
Hi, I am using this lisp for analytic calculation areas in architectonic drawings. Is it possible to update the code to support trapezoid area ?
E = 1/2 x (a+b) x h
(defun c:areacal ( / js nb ent dxf_ent ptlst surf n AcDoc Space old_textsize count app_txt cum_area pt_ins val_txt lst_bis l_4d max_d pos pt1 pt2 pt3 d1 d2 nw_obj ent_text key)
       (command "_layer" "_m" "AREA CALC" "_c" "7" "" "")
       (command "_.-style" "AREA CALC" "arial.ttf" 2.5 "1" "0" "n" "n" "n")
	(while (null (setq js (ssget '((0 . "LWPOLYLINE") (-4 . "<AND") (-4 . "&") (70 . 1) (-4 . ">") (90 . 2) (-4 . "<") (90 . 5) (-4 . "AND>"))))))
	(repeat (setq nb (sslength js))
		(setq
			ent (ssname js (setq nb (1- nb)))
			dxf_ent (entget ent)
			ptlst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_ent))
			n (length ptlst)
		(if (eq n 4)
			(if (not (and (equal (distance (car ptlst) (cadr ptlst)) (distance (caddr ptlst) (cadddr ptlst)) 1E-08)))
				(ssdel ent js)
	(cond
		((and js (> (sslength js) 0))
			(sssetfirst nil js)
			(initget "Yes No")
			(cond
				((not (eq (getkword "\n Insert calculations [Yes/No]? <Yes>: ") "No"))
					(sssetfirst nil nil)
					(setq
						AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
						Space
						(if (= 1 (getvar "CVPORT"))
							(vla-get-PaperSpace AcDoc)
							(vla-get-ModelSpace AcDoc)
						old_textsize (getvar "TEXTSIZE")
						count 0
						app_txt ""
						cum_area 0.0
					(setvar "TEXTSIZE" 2.5)
						(setq
							n (length ptlst)
							pt_ins (list (/ (apply '+ (mapcar 'car ptlst)) n) (/ (apply '+ (mapcar 'cadr ptlst)) n))
							val_txt
							(if (eq n 3)
								(progn
									(setq
										lst_bis (append (cdr ptlst) (list (car ptlst)))
										l_4d (mapcar 'distance ptlst lst_bis)
										max_d (apply 'max l_4d)
										pos (vl-position max_d l_4d)
										pt1 (nth pos ptlst)
										pt2 (nth pos lst_bis)
										pt3 (car (vl-remove pt2 (vl-remove pt1 ptlst)))
										d1
										(distance
											pt3
											(inters
												pt1
												pt2
												pt3
												(polar pt3 (+ (angle pt1 pt2) (* pi 0.5)) (distance pt1 pt2))
												nil
										surf (* (atof(rtos max_d 2 2)) (atof (rtos d1 2 2)) 0.5)
										cum_area (atof (rtos (+ surf cum_area) 2 2))
									(strcat
										"Ε" (itoa (setq count (1+ count))) " = "
										"1/2 x "
										(rtos max_d 2 2)
										" x "
										(rtos d1 2 2)
										(rtos surf 2 2) " sq.m\\P"
								(progn
									(setq
										d1 (atof (rtos (distance (car ptlst) (cadr ptlst)) 2 2))
										d2 (atof (rtos (distance (cadr ptlst) (caddr ptlst)) 2 2))
										surf (atof (rtos (* d1 d2) 2 2))
									(strcat
										(rtos d1 2 2)
										" x "
										(rtos d2 2 2)
										(rtos surf 2 2)
										" sq.m\\P"
							app_txt (strcat app_txt val_txt)
						(entmake
							(list
								'(0 . "TEXT")
								'(100 . "AcDbEntity")
								(cons 8 (getvar "CLAYER"))
								'(100 . "AcDbText")
								(cons 10 pt_ins)
								(cons 40 (getvar "TEXTSIZE"))
								(cons 1 (strcat "E" (itoa count)))
								(cons 50 (angle '(0 0 0) (getvar "UCSXDIR")))
								'(41 . 1.0)
								'(51 . 0.0)
								(cons 7 (getvar "TEXTSTYLE"))
								'(71 . 0)
								'(72 . 1)
								(cons 11 pt_ins)
								(assoc 210 dxf_ent)
								'(100 . "AcDbText")
								'(73 . 2)
					(setq nw_obj
						(vla-addMtext Space
							(vlax-3d-point (trans (getvar "VIEWCTR") 1 0))
							0.0
							(strcat app_txt "Εολ = " (rtos cum_area 2 2) " sq.m")
					(mapcar
						'(lambda (pr val)
							(vlax-put nw_obj pr val)
						(list 'AttachmentPoint 'Height 'DrawingDirection 'StyleName 'Layer 'Rotation 'BackgroundFill 'Color)
						;(list 1 (getvar "TEXTSIZE") 5 (getvar "TEXTSTYLE") (getvar "CLAYER") 0.0 -1 250)
						(list 1 (getvar "TEXTSIZE") 5 (getvar "TEXTSTYLE") (getvar "CLAYER") 0.0 0 0)
					(setq
						ent_text (entlast)
						dxf_ent (entget ent_text)
						dxf_ent (subst (cons 90 1) (assoc 90 dxf_ent) dxf_ent)
						dxf_ent (subst (cons 63 255) (assoc 63 dxf_ent) dxf_ent)
					(entmod dxf_ent)
					(while (and (setq key (grread T 4 0)) (/= (car key) 3))
						(cond
							((eq (car key) 5)
								(setq dxf_ent (subst (cons 10 (trans (cadr key) 1 0)) (assoc 10 dxf_ent) dxf_ent))
								(entmod dxf_ent)
					(setvar "TEXTSIZE" old_textsize)
				(T (sssetfirst nil nil) (princ "\nFunction canceled"))
		(T (princ "\nSelected items are invalid"))
;layer 0
(mapcar 'setvar '("clayer" "cecolor" "celtype" "celweight") (list "0" "BYLAYER" "BYLAYER" -1))
(*error* "")
Re: Trapezoid area lisp
Hi SPirou4D. This code select close polylines rectangles and triangrles and insert calculate the area, and insert text with analytic calculation of this areas. I want to add in this code to calculate the area of trapezoid, with the type E = 1/2 x (a+b) x h . Can any one help?
The lisp above works on the Rectangle only.
Please refer to simple lisp to get the area property of the LwPolyline:
(defun c:areacal (/ area dxf_ent ent js n nb ptlst pt_ins)
  (if (setq js (ssget '((0 . "LWPOLYLINE")
			(-4 . "<AND")
			(-4 . "&")
			(70 . 1)
			(-4 . ">")
			(90 . 2)
			(-4 . "<")
			(90 . 5)
			(-4 . "AND>")
    (progn
	(setq ent     (ssname js (setq nb (1- nb)))
	      ptlst   (mapcar 'cdr
			      (vl-remove-if-not
				dxf_ent
	      n	      (length ptlst)
	      area    (vla-get-Area (vlax-ename->vla-Object ent))
	(entmake
	  (list
	    '(0 . "TEXT")
	    (cons 10 pt_ins)
	    (cons 1 (strcat "Area= " (rtos area)))
	    (cons 72 4)
	    (cons 11 pt_ins)
select rectangles / triangles / close polylines
calculate their areas
= add in this code to calculate the area of trapezoid,
function [1/2 x (a+b) x h ]
What is a ?
What is b ?
What is h ?
This lisp use the unique width and height but not a second width b for rectangles or closed polylines.
so you must modify this code for number of points <= 4 points and h egual height :
1 with a first width egual to 0 and a second width b for triangles.
2 with a second width b egual to first width a when rectangles.
3 idem with closed polylines.
4 with a and b and h for trapezoidal.
HERE=>
		(setq
			n (length ptlst)
		(if (eq n 4)
				(ssdel ent js)
Good luck!
The area and length of any Plines shows in the Properties window and under List, was there some other reason you needed to code for?
Sorry if I don't understand the full meaning of your question.
Hope this helps.
-=(RH)=-
ProM wrote: ↑
Sun Dec 11, 2022 6:59 am
E = 1/2 x (a+b) x h
-=(RLH)=-
This code is weird, you must select the item your-self?
I try it in French UI but I can't understand how it work.....I will try in US UI.
Explanations:
1 layer creation
2 go to the new layer to write
3 choose the style of the text
4 ask if you write the text backwards
5 ask if you write the text upside-down
6 select the items
7 ask if you write the calculations
8 "error: application is locked and cannot be unloaded." ???
I mean your code is for AutoCAD but not for IntelliCAD !
rhgrafix was right, area is calculated automatically for all items or you can use the _AREA command too....
If you answer to this list of parameters, we can help you. Coding is not a riddle :
; js = ?
; nb =
; ent =
; dxf_ent =
; ptlst =
; surf =
; n =
; AcDoc =
; Space =
; old_textsize =
; count =
; app_txt =
; cum_area =
; pt_ins =
; val_txt =
; lst_bis =
; lst_bis =
; l_4d =
; max_d =
; pos =
; pt1 =
; pt2 =
; pt3 =
; d1 =
; d2 =
; nw_obj =
; ent_text =
; key =
#11
I found the solution to your problem: You must remove this code in 45-49 lines:
; Delete Trapezoids in selection
(if (eq n 4)
	(ssdel ent js)
.......; to selection trapezoids too in area calculation of this script.
#12
ProM wrote: ↑
Sun Dec 11, 2022 4:27 pm
Do you want something like this? (E3 figure)
#13
Here is a real trapezoid =
For me, Trapezoids area is triangle ABC area + triangle CDA area
E1 = 1/2 x (h1 + h2) x largest diagonal
Example here :
E1 = 0.5 x (35.78 x 47.69) = 853.47
So you look for the largest diagonal
and in the code, line 46-79 there are triangle calculation, you can re-use it two times.....
Good luck !
#14
Here is my new script for your demand :
(vl-load-com)
(defun c:areacal (/ js nb ent dxf_ent ptlst surf n AcDoc Space old_textsize count app_txt cum_area pt_ins val_txt lst_bis l_4d max_d pos pt1 pt2 pt3 d1 d2 diag1 diag2 diag max_diag pt4 surf1 surf2  nw_obj ent_text key)
	(command "_.-style" "AREA CALC" "arial.ttf" 2.5 "1" "0" "No" "No")
		(setq
			n (length ptlst)
	(cond
			(sssetfirst nil js)
			(initget "Yes No")
			(cond
					(setq
						Space
						count 0
						app_txt ""
						cum_area 0.0
						(setq
							n (length ptlst)
							val_txt
							(if (eq n 3)
								; triangles
								(progn
									(setq
										pt1 (nth pos ptlst)
										d1
										(distance
											pt3
											(inters
												pt1
												pt2
												pt3
												nil
										surf (* (atof(rtos max_d 2 3)) (atof (rtos d1 2 3)) 0.5)
										cum_area (atof (rtos (+ surf cum_area) 2 3))
									(strcat
										"E" (itoa (setq count (1+ count))) " = "
										"1/2 x "
										(rtos max_d 2 2)
										" x (ht "
										(rtos d1 2 2)
										(rtos surf 2 2) " m2\\P"
								; equilateral
								(if (and
									(equal (distance (car ptlst) (cadr ptlst)) (distance (caddr ptlst) (cadddr ptlst)))
									(equal (distance (car ptlst) (caddr ptlst)) (distance (cadr ptlst) (cadddr ptlst))))
									(progn
										(setq
											d1 (atof (rtos (distance (car ptlst) (cadr ptlst)) 2 3))
											d2 (atof (rtos (distance (cadr ptlst) (caddr ptlst)) 2 3))
											surf (atof (rtos (* d1 d2) 2 3))
										(strcat
											(rtos d1 2 2)
											" x "
											(rtos d2 2 2)
											(rtos surf 2 2)
											" m2\\P"
									; trapezoidals
									(progn
										(setq
											diag1 (distance (car ptlst) (caddr ptlst))
											diag2 (distance (cadr ptlst) (cadddr ptlst))
											diag (list diag1 diag2)
											max_diag (apply 'max diag)
											pt1 (if(> diag1 diag2) (car ptlst) (cadr ptlst))
											pt2 (if(> diag1 diag2) (caddr ptlst) (cadddr ptlst))
											pt3 (if(> diag1 diag2) (cadr ptlst) (caddr ptlst))
											pt4 (if(> diag1 diag2) (cadddr ptlst) (car ptlst))
											d1
											(distance
												pt3
												(inters
													pt1
													pt2
													pt3
													nil
											d2
											(distance
												pt4
												(inters
													pt1
													pt2
													pt4
													(polar pt4 (+ (angle pt1 pt2) (* pi 0.5)) (distance pt1 pt2))
													nil
											ht 	(atof (rtos (+ d1 d2) 2 3))
											surf (* (atof(rtos max_diag 2 3)) (atof (rtos ht 2 3)) 0.5)
										(strcat
											"1/2 x "
											(rtos max_diag 2 2)
											" x (ht "
											(rtos ht 2 2)
						(entmake
							(list
								'(0 . "TEXT")
								'(100 . "AcDbText")
								(cons 10 pt_ins)
								'(41 . 1.0)
								'(51 . 0.0)
								'(71 . 0)
								'(72 . 1)
								(cons 11 pt_ins)
								(assoc 210 dxf_ent)
								'(100 . "AcDbText")
								'(73 . 2)
					(setq nw_obj
						(vla-addMtext Space
							0.0
							(strcat app_txt "TOTAL = " (rtos cum_area 2 2) " m2")
					;(setq entvla (vlax-ename->vla-object (car (entsel "\nChoix de l'entité\n"))))
					;(vlax-dump-object entvla)
					(mapcar
						'(lambda (pr val)
						(list 'AttachmentPoint 'color 'DrawingDirection 'Height 'Layer 'Linetype 'LinetypeScale 'Lineweight 'StyleName 'Rotation 'Visible)
						(list 1 18 1 (getvar "TEXTSIZE") (getvar "CLAYER") (getvar "LINETYPE") 1 (getvar "LINEWEIGHT") (getvar "TEXTSTYLE") 0.0 -1)
					(setq
						ent_text (entlast)
					(entmod dxf_ent)
						(cond
							((eq (car key) 5)
								(entmod dxf_ent)
				(T (sssetfirst nil nil) (princ "\nFunction canceled because no calculation"))
;return on the layer 0
(*error* "Modify your code !")
#15
BUT I can't remove to this problem :
error: too few arguments
nil
If someone can help me to correct this Please !
I think the error come from this code:
(setq
						ent_text (entlast)
