Right Click shortcut menu customize
pcacciot
pcacciot
Mon Nov 30, 2020 8:38 am
#1 by pcacciot
Hello all,
I would like to ask if there was a way to customize the right click shortcut menu. I would like to add trim and extend to the shortcut menu.
I looked through the "Customize User Interface" and don't see the shortcut menu there.
Thanks for your help!
Paul
  • Thu Apr 14, 2022 2:39 pm
pcacciot
pcacciot
Re: Right Click shortcut menu customize
#2 by pcacciot
Any answers on this? Or plans to add this feature?
  • Wed Nov 16, 2022 8:51 am
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 9:11 am
