Re: DVB file
#16
Hi Steven,
Please refer to the official document and modify it to fix with the IntelliCAD.
Select method.png (130.03 KiB) Viewed 62610 times
Here's the modified function SSetCreate base on your one.
Function SSetCreate(d_SetName As String, d_Mode As Integer, d_Data As String) As SelectionSet
    Dim t_SSET As SelectionSet
    Dim t_Point1 As Point
    Dim t_Point2 As Point
    Dim t_Code1 As Variant
    Dim t_Value1 As Variant
    Set t_Point1 = Library.CreatePoint(0, 0)
    Set t_Point2 = Library.CreatePoint(300, 200)
    t_Code1 = d_Mode
    t_Value1 = d_Data
    Set t_SSET = ActiveDocument.SelectionSets.Add(d_SetName)
    'ActiveDocument.SendCommand ("zoom all" + vbCr)
    t_SSET.Select vicSelectionSetAll, t_Point1, t_Point2, t_Code1, t_Value1
    'ActiveDocument.SendCommand ("zoom p" + vbCr)
    Set SSetCreate = t_SSET
End Function
Re: DVB file
#18
Could we (you :) ) have used vicSelectionSetInsideWindow as an alternative to vicSelectionSetAll ?
and if yes, how would that impact the code?
I believe that the code is looking for the block "DAPDRB00" within the window contained within the points 1 & 2
Re: DVB file
#19
Hi Steven,
First, the above only is converting your AutoCAD code to work on IntelliCAD.
Yes, in case you want to select the block named "DAPDRB00" within a rectangle defined by two point corners, you should use the parameter vicSelectionSetInsideWindow instead.
t_SSET.Select vicSelectionSetInsideWindow, t_Point1, t_Point2, t_Code1, t_Value1
Re: DVB file
#20
Thanks again Quan.
MY understanding of this section of code is looking for a block (dxf code 2) that is named DAPDRB00 inside the window (0,0 to 300,200).
If it does then it loads the form DAP_DPP.
    If (t_SSET.Count = 1) Then
        Set t_Form = DAP_DPP
         t_Form.Show
What is actually happening when i select the macro :
If the drawing is empty the form does not display, and a zoom all is executed. as expected.
However if ANY entity is in the drawing in any location the form is loaded??
Here is what I have
'--------original-------
'    Dim t_Point1(0 To 2) As Double
'    Dim t_Point2(0 To 2) As Double
'    Dim t_Code1(0) As Integer
'    Dim t_Value1(0) As Variant
'    Dim t_Code2 As Variant
'    Dim t_Value2 As Variant
'    t_Point1(0) = 0: t_Point1(1) = 0: t_Point1(2) = 0
'    t_Point2(0) = 300: t_Point2(1) = 200: t_Point2(2) = 0
'    t_Code1(0) = d_Mode
'    t_Value1(0) = d_Data
'    t_Code2 = t_Code1
'    t_Value2 = t_Value1
'--------QUAN-------
    t_Code1 = d_Mode
    t_Value1 = d_Data
    t_SSET.Select vicSelectionSetAll, t_Point1, t_Point2, t_Code1, t_Value1 'Quan
'   t_SSET.Select vicSelectionSetInsideWindow, t_Point1, t_Point2, t_Code1, t_Value1 'was vicSelectionSetAll
End Function
When I use F8 to step through the code, stopping at the final Set SSetCreate = t_SSET. I can place the mouse over t_Code1 and see it's value (2) and t_Value1 (DAPDRB00). but nothing for either point.
Re: DVB file
#23
User Error!! I was trying to watch the complete expression, not individual components!!
Note: at this point the drawing contains a single rectangle -10,-10,0 to 310,210,0 (this is intended to be outside the search window)
I have placed watches on t_point1 & t_point2 and as I increment through the code, 1 returns 0,0,0 as double; 2 returns 300,200,0,as double.
Adding a watch to 't_SSET' in the closing statement Set SSetCreate = t_SSET gives me a count of zero and a name of "TEMP_SSET".
Now, adding a line from 50,50, to 250,150 (within the search window) and the incrementing through the code give:
Sorry not the best image, but
t_SSET now has a count of 1 ? is this correct??
Re: DVB file
#25
Hi Quan, Thanks
Made no difference :(
Did you want me to attache a copy of the "DAPDRB00" to this thread or the test drawing?
Steve
P.S.
Zip file attached containing drawing with "DAPDRB00" inserted & the vbi as it stands.
SLN-DAP.zip
(103.56 KiB) Downloaded 1300 times
Re: DVB file
#26
Hi Steve,
Please use this function to get the block in the attached drawing.
    Dim t_Code As Variant
    Dim t_Value As Variant
    Dim FilterType(0 To 0) As Integer
    Dim FilterData(0 To 0) As Variant
    FilterType(0) = d_Mode
    FilterData(0) = d_Data
    t_Code = FilterType
    t_Value = FilterData
    Set t_Point2 = Library.CreatePoint(12, 8)
    ActiveDocument.SendCommand ("zoom all" + vbCr) ' zoom to 0,0 12,8
    t_SSET.Select vicSelectionSetInsideWindow, t_Point1, t_Point2, t_Code, t_Value
End Function
Re: DVB file
#27
Many thanks Quan, that works :)
I did have to make a small change:
    t_Code1 = FilterType
    t_Value1 = FilterData
I will spend some time over the weekend studying your changes to understand them more.
On a side note, the dwg in the zip was hurriedly created and used an imperial template, we are metric here in the UK so I have kept the window as 0,0 / 300,200.
Re: DVB file
#28
I've moved on a little, though work is getting in the way!!
Next problem is associated with Attributes.
here is the code:
Sub DynamicFormLoad(d_Form As Variant, d_Handle As String)
    Dim t_SREF As BlockInsert 					 'was AcadBlockReference
    Dim t_SATT As Variant
    Dim t_Index As Integer
    Dim t_FATT As Variant                                    	 'Dim t_FATT As Control
    Set t_SREF = ActiveDocument.HandleToObject(d_Handle)      'was ThisDrawing
    If (t_SREF.HasAttributes) Then
        t_SATT = t_SREF.GetAttributes
        For t_Index = LBound(t_SATT) To UBound(t_SATT)
            On Error GoTo DynamicFormLoad1
            Set t_FATT = d_Form.Controls.Item(t_SATT(t_Index).TagString)
            t_FATT.Text = t_SATT(t_Index).TextString
DynamicFormLoad2:
            On Error GoTo 0
            Next t_Index
    d_Form.Tag = d_Handle
    Exit Sub
DynamicFormLoad1:
    Resume DynamicFormLoad2
I've shown the original code where I've made changes.
Current problem:
doesn't work, and gives a 'runtime error 450'
This looks to be the same issue as here : viewtopic.php?t=3218&sid=8e104d3c0271ac ... 2a03891c76
Question: is it the same? & should I try to follow the solution in that thread?
NOTE: I have 50 attributes!!
Re: DVB file
#30
Hi Quan,
I tried:
'    Set t_SREF = ActiveDocument.HandleToObject(d_Handle)      'was ThisDrawing
Same error message
