Since version 2021 Progesoft offers the DATAEXTRACTION command with wizard.
When will CMS Intellicad also offer this indispensable command?
P.S. I can't find a WishList section in the forum
Re: DATAEXTRACTION
#2I just had a look at the Progesoft website and this is there description:
"Advanced Data Extraction - An easy-to-use wizard for Attributes and Blocks data export"
So is this the same as in Intellicad:
(Note I use the menu bar setup)
Go to Tools dropdown and select 'Extract Attributes'
Steve
Steve
Re: DATAEXTRACTION
#3What you mention is the ATTEXT command
What I'm referring to is the DATAEXTRACTION command
Added in Progesoft in the 2021 version of which I am attaching the brochure with the subject highlighted.
- Attachments
- brochure_progesoft_ENG_2021-PRINT1.jpg (113.95 KiB) Viewed 17556 times
