Hi all
from 10.1 update (first 9.0 in my laptop) my PE+ is slowing down in unacceptable way special when have some images linked in.
The refresh is very laggy and mouse movements so scatter than sometimes it's impossible to have a fluid work with.
Trying to solve this using the lowest graphical settings (in the bottom right of interface) :
Basic option with "2D-3D line smoothing" set to off
But nothing to do... it continue to lag at every scrolling and refresh.
My Laptop is a 2016 ASUS (X750J) 17"screen+CPU i7+8Gram+NVidia740M
Re: PE+ Too much lags in drawing scrolling with images inserted (not in 9.0 ver but from 10.1 update)
#2I've run into similar things with different drawings with no real identifiable cause. Going to BASIC or Intermediate graphics settings did not have huge improvements.
I will suggest looking at your CPU affinity settings. I think the default is to use the least used core and 10.1 is really designed to use multiple cores. I've had best results setting it to all 8 cores when doing some large 3D models.
Give it a try and let us know.
#3Hi
My CMS Affinity Setting is already set to "All cores".
Anyway...Thanks for hint.
#4The only other thing I could suggest is that once I was putting together a large 3D model and it started having serious lagging issues. I ended up starting a completely new drawing, opened the model and copy-pasted all the objects into the new drawing. The size dropped about 35% and the speed improved dramatically, There had to be some garbage in the drawing that audit and purge did not clear out but I can't say what it was for sure.
Anyway, if it is one drawing that is giving you trouble, you can give that a try.
