Display problems
Posted: Mon Jan 04, 2021 12:29 pm
by FrancescoMed74
Dear Support Team
I'm evaluating CMS Intellicad 10 Premium ed plus.
I tried to open several dwg files from Autocad (rel 14 to 2018) but CMS intellicad is not able to show circles, lines and so on.
I tried to select them and I saw that the objects are detected but not shown.
I changed color, thickness but final result is not acceptable.
I would like to understand if the problem is related to specific settings or bad compatibility with Autocad.
Thanks in advance
Francesco
Re: Display problems
Posted: Sun Jan 10, 2021 6:03 pm
by CMS Inc
Looks like your system and device graphics is not updated or does not properly support OpenGL ES graphics technology.
Make sure to force a windows update and also an update of your graphics device driver.
You can also tweak graphics visibility/settings using command GRAPHICSCONFIG.
Posted: Sat Jan 16, 2021 7:57 am
by FrancescoMed74
SOLVED. I've just deactivated 2D/3D anti-aliasing.
Thank you
Posted: Sat Jan 16, 2021 3:33 pm
by CMS Inc
Thank you for the feedback. Looks like the graphics driver is not that fun of OpenGL technology.
Posted: Sun Jan 17, 2021 8:05 am
by FrancescoMed74
anoher good solution
tools-options-display-graphic performance and change OpenGL ES with OpenGL (leaving 2D and 3D antialiasing selected).
