Display problems
Dear Support Team
I'm evaluating CMS Intellicad 10 Premium ed plus.
I tried to open several dwg files from Autocad (rel 14 to 2018) but CMS intellicad is not able to show circles, lines and so on.
I tried to select them and I saw that the objects are detected but not shown.
I changed color, thickness but final result is not acceptable.
I would like to understand if the problem is related to specific settings or bad compatibility with Autocad.
Thanks in advance
Francesco
Re: Display problems
Looks like your system and device graphics is not updated or does not properly support OpenGL ES graphics technology.
Make sure to force a windows update and also an update of your graphics device driver.
You can also tweak graphics visibility/settings using command GRAPHICSCONFIG.
