Re: perimeter
Hi Zdenko,
There is not a 'perimeter' command, however if your object is a circle/closed polyline/closed shape then if you select the object and then use the 'list' command this will give you the perimeter.
hth
Re: perimeter
Hi Zdenko,
the perimeter of your object needs to be drawn with a Polyline.
then using the List command (type - list entity information - into the search bar in the help section)
Your should get something like this:
Re: perimeter
It depends on the objects or entities.
If it's a closed object, if applicable, use PROPERTIES command or AREA command.
If not, then use BOUNDARY command. It will create a closed polyline entity. Then use AREA of selected entity.
