TotalAngle in arc object
ENSIGN
Post by ENSIGN » Tue Sep 19, 2006 2:42 am
the TotalAngle variable appears to be missing from the Arc object in intellicad
Our AutoCAD code is,
Dim Retarc as Arc
Set Retarc = IntelliCAD.ActiveDocument.ModelSpace.AddArc(CP1, ArcRad, CP1Ang2, CP1Ang1)
Retarc.Update
LimitAng = Retarc.TotalAngle
This returns the total angle of an arc
Note. TotalAngle is available in Autocad but not Intellicad. Is there a replacement command for this. or another way of calculating the total angle of an arc.
Post by John Finlay » Wed Jul 11, 2007 12:31 am
Ensign,
The calculation for TotalAngle are:
TotalAngle = Arc Length / Radius
The value is in Radians.
Sorry, I just noticed that there was no reply to your email.
BJ
Autolisp routine
Post by BJ » Wed Jul 11, 2007 12:07 pm
I have a AutoLisp routine that will run in IC that calculates the
arc length. It only works for arcs up to 180 degrees though.
This gives an example of what it prints in the status box:
Arc Length= 7'-1 15/16" Rad= 3'-11" M.O.= 1'-6 5/16"
Chrd= 6'-2 7/16" Ang= 104.72215534
I can post it if you want it.
It could be modified for decimal instead of feet and inches pretty easy.
ENSIGN
totalangle
Post by ENSIGN » Fri Jul 27, 2007 2:37 am
we got round the problem, thx for the replies though
