VBA and the Prompt method
ActiveDocument.Utility.Prompt "message"
Activedocument.Utility.Getstring
I have a program written that searches for a particular text value (or mtext value) in a document. It works fine but I am having one problem with the command prompt. If I try to issue a getstring command after using the prompt command I get an error. For some reason the getstring command is showing up on the same line as the prompt command like it needs a carriage return. I can't find anything that issues a carriage return in VB (ie the space bar) Anyone got a clue?
