I am trying to create a Block in Cadopia 6 Pro.
Here is the stripped down code I am using:
Dim CurrentDwg As Document
Dim TempBlock As IntelliCAD.Block
Dim InsertPoint As IntelliCAD.Point
Set CurrentDwg = Application.ActiveDocument
Set InsertPoint = Library.CreatePoint(0, 0, 0)
Set TempBlock = CurrentDwg.Blocks.Add(InsertPoint, "FOOBAR")
The last line produces the following error message:
Run-time error '-2147467259(80004005)':
Method 'Add' of Object "IIcadBlocks' failed
(Whew! That's a great error number!)
I have also tried this:
Set TempBlock = IntelliCAD.Blocks.Add(InsertPoint, "FOOBAR")
Same error.
This sure looks like the same sort of code in the Developer's
Reference.
Can someone show me the error of my ways?
Thanks in advance.
ssc -
Thanks for the response. I am trying to create a Block, not just Insert it.
In other words, I am trying to create a Block object using VBA code, not just place an existing Block somewhere in the .DWG.
I know I can use a template .DWG to get around this (which I am currently doing), but the basic code I am working with runs OK in ACAD and I would like to port all of the program (if possible) directly to ICAD.
Mostly curious about what I am doing wrong.
