GetPoint
The GetPoint method will not snap to anything if you provide a "relative" point arguement for rubber banding.
eg: GetPoint(varPoint1, "Pick Next Point")
Any workarounds? Will the GetPoint method ever be repaired? It seems to be biffed in every version of ICAD.
gsprink,
The code below will snap to the end point.
Set SnapSet = IntelliCAD.ActiveDocument.Utility.EntitySnap(IntelliCAD.ActiveDocument.Utility.GetPoint(, "Select Point"), vicOsnapEnd)
