Would you like to save different layer states in IntelliCAD? I put this together, not the best piece of code but it works. It will save layer states to a text file in the drawing directory. It retrieve said states when picked from a list box. The funny thing is it will not work on the default ICAD drawing (when ICAD is initially open)-- the command Document.Path does not get this default drawing Path (strange), works if the drawing has been saved.
I did not find a way to access viewport layer states, any ideas??
Comments are encouraged and welcome.
You will need a form with the following:
listbox lboDrawingLayers
listbox lboRestoreState
Button cmdOK
Button cmdCancel
Button cmdLayerStateSave
Code follows (sorry for the length could be smaller):
'Created By Scott Campbell
'03/29/01
'Layer States for IntelliCAD 2000
Option Explicit
Dim objlayer As Layer
Dim mydoc As Document
Dim mydocname As String
Dim myarray As Variant
Dim mypath As String
Dim viewports As WhichViewport
Dim mylayers As Layers
Dim mylayer As Layer
Dim fchkflag As Boolean
Dim mystring As String
Private Sub UserForm_Initialize()
Set mydoc = intellicad.ActiveDocument
Set mylayers = mydoc.Layers
mydocname = VBA.Replace(mydoc.Name, VBA.Chr(46), "") & "-LS" & ".txt" 'replace period with nothing
mypath = mydoc.Path & "\" & mydocname 'create file path
For Each objlayer In intellicad.ActiveDocument.Layers
lboDrawingLayers.AddItem objlayer.Name 'add them to the list box
Next
currentlayerstates
loadstates
Sub loadstates()
Dim stemp As String
lboRestoreState.Clear 'clear the listbox
filechk
If fchkflag = True Then
Open mypath For Input As #1
While Not EOF(1)
Line Input #1, stemp
myarray = Split(stemp, ",")
If myarray(0) = mystring Then
Else
lboRestoreState.AddItem myarray(0)
End If
mystring = myarray(0)
Wend
Close #1 'close the file
Else
End If
Private Sub filechk()
Dim myfolder As String
Dim fs, f, f1, fc, s
myfolder = mydoc.Path 'create file path
Set fs = CreateObject("Scripting.FileSystemObject")
Set f = fs.GetFolder(myfolder)
Set fc = f.Files
For Each f1 In fc
If f1.Name = mydocname Then
fchkflag = True
Else
End If
Next
Sub cmdLayerStateSave_Click()
Dim Message, Title, Default, myvalue
Message = "Enter Layer State Description" ' Set prompt
Title = "Save Layer State" ' Set title
Default = "Original" ' Set default
mystring = InputBox(Message, Title, Default)
If mystring = "" Then 'checks for cancel in inputbox
cmdCancel_Click
Else
End If
Open mypath For Append As #1 'open text file
savelayers
Unload Me 'unload dialogue
Private Sub cmdOK_Click()
mystring = "Cancel"
mydocname = VBA.Replace(mydoc.Name, VBA.Chr(46), "") & mystring & ".txt" 'replace period with nothing
mypath = mydoc.Path & "\" & mydocname 'open cancel file storing states prior to procedure
Kill mypath 'deletes existing layer state txt file on exit
End
Sub cmdCancel_Click()
Dim mycancelpath As String
Dim mycancelname As String
mystring = "Cancel"
restorelayers 'restores layer state prior to initiating procedure
End
Sub lboRestoreState_Click()
Dim stemp As String
Dim rlayer As Variant
Dim rfreeze As Variant
Dim ron As Variant
Dim rlock As Variant
mystring = lboRestoreState.Value
restorelayers
Private Sub currentlayerstates()
Dim lname As String
Dim stemp As String
Dim ron As Variant
mystring = "Cancel"
mycancelname = VBA.Replace(mydoc.Name, VBA.Chr(46), "") & mystring & ".txt" 'replace period with nothing
mypath = mydoc.Path & "\" & mycancelname 'create file path
Open mypath For Output As #1 'open text file
savelayers
Private Sub savelayers()
Dim lname As String
Dim lfreeze As Variant
Dim loff As Variant
Dim llock As Variant
For Each objlayer In intellicad.ActiveDocument.Layers 'start looping thru' the layer names
lname = objlayer.Name
If objlayer.Freeze = True Then
lfreeze = "Frozen"
Else
lfreeze = "Thawed"
End If
If objlayer.LayerOn = True Then
loff = "on"
Else
loff = "off"
End If
If objlayer.Lock = True Then
llock = "locked"
Else
llock = "unlocked"
End If
Print #1, mystring & "," & lname & "," & lfreeze & "," & loff & "," & llock 'print it to the file
Next
Private Sub restorelayers()
Dim stemp As String
Dim ron As Variant
While Not EOF(1)
rlayer = myarray(1)
Set mylayer = mylayers.Item(rlayer)
rfreeze = myarray(2)
If rfreeze = "Thawed" Then
mylayer.Freeze = False
Else
mylayer.Freeze = True
End If
ron = myarray(3)
If ron = "on" Then
mylayer.LayerOn = True
Else
mylayer.LayerOn = False
End If
rlock = myarray(4)
If rlock = "locked" Then
mylayer.Lock = True
Else
mylayer.Lock = False
End If
Else
End If
Wend
viewports = vicActiveViewport
intellicad.ActiveDocument.Regen ([viewports])
'End Code
Scott
Layer States
- CMS IntelliCAD
- - General
- - AutoLisp/SDS
- - VBA, . NET & IRX
- - - FAQ
- - New User
- - Small Business
- - Realistic Rendering
- - Bonus
- - Free CAD .DWG Blocks
- - License Management
- - Academic
- QuoteCAD Manufacturing
- - General
- - Database Manager
- ETOOLBOX CAD Viewer
- - General
- - License management
