John,
1. How do I retrieve the current drawing dimscale value (vba method)?
2. How do I change the dimscale value and then update the drawing with the changed value?
3. In creating a form and using a combobox with two columns I noticed that vba will not accept a columnwidth of 0 (zero) to hide a column. I have to use a small number such as 0.1 instead. Is this a bug?? Excel will accept a zero value.
Thank you,
Scott
Figured out how to access "dimscale"
Private Sub CommandButton1_Click()
Set myapp = IntelliCAD.Application
Set mydoc = IntelliCAD.ActiveDocument
sysvarname = "dimscale"
mydimscale = 50
sysvardata = mydimscale
mydoc.SetVariable sysvarname, sysvardata
TextBox1 = mydoc.GetVariable(sysvarname)
VBA is a little different than what I am used to.
This takes care of questions 1 & 2. Question 3 still remains.
Thank you,
Scott
Will Post complete routine when done
[This message has been edited by Scott (edited 01-26-2002).]
mydimscale = 50
Thank you,
Scott
For all to use to change drawing dimscale (Text size, dimension global scale factor for different plot scales)
Code as follows:
<B>Option Explicit
Dim myapp As intellicad.Application
Dim mydoc As intellicad.Document
Dim mydimscale As Double
Dim mytxtsize As Double
Dim mytxtmultiply As Double
Dim dsvardata As Double
Dim dsvarname As String
Dim duvardata As Long
Dim duvarname As String
Dim txtvarname As String
Dim txtvardata As Double
Private Sub cmd075ht_Click()
mytxtmultiply = 0.75
Private Sub cmd100ht_Click()
mytxtmultiply = 1
Private Sub cmd125ht_Click()
mytxtmultiply = 1.125
Private Sub cmdCancel_Click()
End ' When the user selects the Cancel Button the program ends
Private Sub cmdARCH_Click()
cboDIMSC.Clear 'Clears cbodimsc combobox of any entries
Call archunits
Private Sub cmdCivil_Click()
cboDIMSC.Clear
Call civilunits
Private Sub UserForm_Initialize()
cmdARCH.GroupName = "units" 'Isolates option button to group units
cmdCivil.GroupName = "units" 'Isolates option button to group units
cmd075ht.GroupName = "txtht" 'Isolates option button to group txtht
cmd100ht.GroupName = "txtht" 'Isolates option button to group txtht
cmd125ht.GroupName = "txtht" 'Isolates option button to group txtht
Set myapp = intellicad.Application
Set mydoc = intellicad.ActiveDocument
dsvarname = "dimscale"
duvarname = "dimunit"
txtvarname = "textsize"
cmd100ht.Value = "true" 'Sets 0.1" text height option button as default
Select Case mydoc.GetVariable(duvarname) 'Find value of current dimunit variable
Case 1, 2, 3, 5, 7 'Dimunit value
cmdCivil.Value = "true" 'Sets civil option button
GoTo civil
Case 4, 6 'Dimunit value
cmdARCH.Value = "true" 'sets architectural option button
GoTo architectural
End Select
architectural:
Select Case mydoc.GetVariable(dsvarname) 'Get current dimscale
Case 1
txtCDIMSC = "Full Scale 1:1" 'The textual label
cboDIMSC.Text = txtCDIMSC
Case 192
txtCDIMSC = "1/16" & Chr(34) + "= 1'-0" & Chr(34)
Case 128
txtCDIMSC = "3/32" & Chr(34) + "= 1'-0" & Chr(34)
Case 96
txtCDIMSC = "1/8" & Chr(34) + "= 1'-0" & Chr(34)
Case 64
txtCDIMSC = "3/16" & Chr(34) + "= 1'-0" & Chr(34)
Case 48
txtCDIMSC = "1/4" & Chr(34) + "= 1'-0" & Chr(34)
Case 32
txtCDIMSC = "3/8" & Chr(34) + "= 1'-0" & Chr(34)
Case 24
txtCDIMSC = "1/2" & Chr(34) + "= 1'-0" & Chr(34)
Case 16
txtCDIMSC = "3/4" & Chr(34) + "= 1'-0" & Chr(34)
Case 12
txtCDIMSC = "1" & Chr(34) + "= 1'-0" & Chr(34)
Case 8
txtCDIMSC = "1-1/2" & Chr(34) + "= 1'-0" & Chr(34)
Case 4
txtCDIMSC = "3" & Chr(34) + "= 1'-0" & Chr(34)
End Select
civil:
Case 120
txtCDIMSC = "1" & Chr(34) + "= 10'" 'The textual label
Case 240
txtCDIMSC = "1" & Chr(34) + "= 20'"
Case 360
txtCDIMSC = "1" & Chr(34) + "= 30'"
Case 480
txtCDIMSC = "1" & Chr(34) + "= 40'"
Case 600
txtCDIMSC = "1" & Chr(34) + "= 50'"
Case 720
txtCDIMSC = "1" & Chr(34) + "= 60'"
Case 1200
txtCDIMSC = "1" & Chr(34) + "= 100'"
End Select
Sub archunits()
architectural:
cboDIMSC.AddItem 1 'Adding the dimscale multiplier to combobox (cbodimsc)
cboDIMSC.List(0, 1) = "Full Scale 1:1" 'The textual label to combobox corresponding to item 1
cboDIMSC.AddItem 192 'Adding the dimscale multiplier
cboDIMSC.List(1, 1) = "1/16" & Chr(34) + "= 1'-0" & Chr(34) 'The textual label
cboDIMSC.AddItem 128
cboDIMSC.List(2, 1) = "3/32" & Chr(34) + "= 1'-0" & Chr(34)
cboDIMSC.AddItem 96
cboDIMSC.List(3, 1) = "1/8" & Chr(34) + "= 1'-0" & Chr(34)
cboDIMSC.AddItem 64
cboDIMSC.List(4, 1) = "3/16" & Chr(34) + "= 1'-0" & Chr(34)
cboDIMSC.AddItem 48
cboDIMSC.List(5, 1) = "1/4" & Chr(34) + "= 1'-0" & Chr(34)
cboDIMSC.AddItem 32
cboDIMSC.List(6, 1) = "3/8" & Chr(34) + "= 1'-0" & Chr(34)
cboDIMSC.AddItem 24
cboDIMSC.List(7, 1) = "1/2" & Chr(34) + "= 1'-0" & Chr(34)
cboDIMSC.AddItem 16
cboDIMSC.List(8, 1) = "3/4" & Chr(34) + "= 1'-0" & Chr(34)
cboDIMSC.AddItem 12
cboDIMSC.List(9, 1) = "1" & Chr(34) + "= 1'-0" & Chr(34)
cboDIMSC.AddItem 8
cboDIMSC.List(10, 1) = "1-1/2" & Chr(34) + "= 1'-0" & Chr(34)
cboDIMSC.AddItem 4
cboDIMSC.List(11, 1) = "3" & Chr(34) + "= 1'-0" & Chr(34)
cboDIMSC.TextColumn = 2
Sub civilunits()
civil:
cboDIMSC.AddItem 120 'Adding the dimscale multiplier to combobox (cbodimsc)
cboDIMSC.List(0, 1) = "1" & Chr(34) + "= 10'" 'The textual label to combobox corresponding to item 1
cboDIMSC.AddItem 240 'Adding the dimscale multiplier
cboDIMSC.List(1, 1) = "1" & Chr(34) + "= 20'" 'The textual label
cboDIMSC.AddItem 360
cboDIMSC.List(2, 1) = "1" & Chr(34) + "= 30'"
cboDIMSC.AddItem 480
cboDIMSC.List(3, 1) = "1" & Chr(34) + "= 40'"
cboDIMSC.AddItem 600
cboDIMSC.List(4, 1) = "1" & Chr(34) + "= 50'"
cboDIMSC.AddItem 720
cboDIMSC.List(5, 1) = "1" & Chr(34) + "= 60'"
cboDIMSC.AddItem 1200
cboDIMSC.List(6, 1) = "1" & Chr(34) + "= 100'"
Private Sub cbodimsc_Click()
Select Case cboDIMSC.Value
Case 120, 240, 360, 480, 600, 720, 1200
mytxtsize = cboDIMSC.Value * mytxtmultiply / 120 'Sets text height to 0.1" high for selected Scale
Case 1, 4, 8, 12, 16, 24, 32, 48, 64, 96, 128, 192
mytxtsize = cboDIMSC.Value * mytxtmultiply / 10 'Sets text height to 0.1" high for selected Scale
End Select
Private Sub cmdok_click()
mydimscale = cboDIMSC.Value
dsvardata = mydimscale
txtvardata = mytxtsize
mydoc.SetVariable dsvarname, dsvardata 'Changes Drawing Dimscale
mydoc.SetVariable txtvarname, txtvardata 'Changes Drawing Text Height
Unload frmDrawingScale
End Sub</B>
Comments welcome
Scott
(do not have a url to post screen shot of form)
Code as follows:
<B>Option Explicit
mytxtmultiply = 1
Call archunits
cboDIMSC.Clear
Call civilunits
GoTo civil
GoTo architectural
End Select
architectural:
Case 1
Case 192
Case 128
Case 96
Case 64
Case 48
Case 32
Case 24
Case 16
Case 12
Case 8
Case 4
End Select
civil:
Case 120
Case 240
Case 360
Case 480
Case 600
Case 720
Case 1200
End Select
Sub archunits()
architectural:
cboDIMSC.AddItem 96
cboDIMSC.AddItem 64
cboDIMSC.AddItem 48
cboDIMSC.AddItem 32
cboDIMSC.AddItem 24
cboDIMSC.AddItem 16
cboDIMSC.AddItem 12
cboDIMSC.AddItem 8
cboDIMSC.AddItem 4
Sub civilunits()
civil:
End Select
End Sub</B>
Comments welcome
Scott
