Page 2 of 2
Re: AcquirePoint
Posted: Wed Jun 16, 2021 4:42 am
by DenisSilveira
Can you send JIG code of yours ... might this is the point ...
Re: AcquirePoint
Posted: Wed Jun 16, 2021 7:00 am
Can you attach your code here then someone can find/debug where the issue does?
Re: AcquirePoint
Posted: Wed Jun 16, 2021 7:49 am
by DenisSilveira
Public Class MoveRotationScaleJig
        Inherits DrawJig
#Region "Fields"
        Private mBase As teigha.geometry.point3d
        Protected mEntities As New List(Of Entity)()
        Private mTotalJigFactorCount As Integer = 3
        Private mCurJigFactorIndex As Integer = 1
        ' Jig Factor Index
        Public mLocation As teigha.geometry.point3d
        ' Jig Factor #1
        Public mAngle As [Double]
        ' Jig Factor #2
        Public mScaleFactor As [Double]
        ' Jig Factor #3
#End Region
#Region "Constructors"
        Public Sub New()
            MyBase.New
            'Dim _ed As Editor = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            'AddHandler _ed.PointMonitor, New PointMonitorEventHandler(AddressOf ed_PointMonitor)
        'Public Sub ed_PointMonitor(sender As Object, e As PointMonitorEventArgs)
        '    mLocation = e.Context.ComputedPoint
        'End Sub
        Public Sub New(basePt As Point3d)
            mBase = basePt.TransformBy(UCS)
            'TODO: Initialize jig factors and transform them if necessary.
            mLocation = mBase
            mAngle = 0
            mScaleFactor = 1
#End Region
#Region "Properties"
        Public Property Location() As teigha.geometry.point3d
            Get
                Return mLocation
            End Get
            Set
                mLocation = Value
            End Set
        End Property
        Public Property Angle() As [Double]
            Get
                Return mAngle
            End Get
            Set
                mAngle = Value
            End Set
        End Property
        Public Property JigFactor As Integer
            Get
                Return mTotalJigFactorCount
            End Get
            Set(value As Integer)
                mTotalJigFactorCount = value
            End Set
        End Property
        Public Property ScaleFactor() As [Double]
            Get
                Return mScaleFactor
            End Get
            Set
                mScaleFactor = Value
            End Set
        End Property
        Public Property Base() As teigha.geometry.point3d
            Get
                Return mBase
            End Get
            Set
                mBase = Value
            End Set
        End Property
        Public ReadOnly Property AcEditor() As Editor
            Get
                Return MgdAcApplication.DocumentManager.MdiActiveDocument.Editor
            End Get
        End Property
        Public ReadOnly Property UCS() As Matrix3d
            Get
                Return AcEditor.CurrentUserCoordinateSystem
            End Get
        End Property
        Public ReadOnly Property IcEditor As Editor
            Get
                Return IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            End Get
        End Property
        Public Property TotalJigFactor As Integer
            Get
            End Get
            End Set
        End Property
        Public ReadOnly Property Transformation() As Matrix3d
            Get
                'return Matrix3d.Identity; //* Change it to anything else meaningful.
                Return Matrix3d.Scaling(mScaleFactor, mLocation).PostMultiplyBy(Matrix3d.Rotation(mAngle, Vector3d.ZAxis.TransformBy(UCS), mLocation)).PostMultiplyBy(Matrix3d.Displacement(mBase.GetVectorTo(mLocation)))
            End Get
        End Property
        Public Property Entities() As List(Of Entity)
            Get
                Return mEntities
            End Get
            Set(value As List(Of Entity))
                mEntities = value
            End Set
        End Property
#End Region
#Region "Methods"
        Public Sub AddEntity(ent As Entity)
            ent.TransformBy(Intellicad.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem)
            mEntities.Add(ent)
        Public Sub TransformEntities()
            Dim mat As Matrix3d = Transformation
            For Each ent As Entity In mEntities
                ent.TransformBy(mat)
            Next
#End Region
#Region "Overrides"
        Protected Overrides Function WorldDraw(draw As WorldDraw) As Boolean
            Dim geo As WorldGeometry = draw.Geometry
            If geo IsNot Nothing Then
                geo.PushModelTransform(mat)
                    geo.Draw(ent)
                Next
                geo.PopModelTransform()
            Return True
        End Function
        Protected Overrides Function Sampler(prompts As JigPrompts) As SamplerStatus
            Select Case mCurJigFactorIndex
                Case 1
                    Dim prOptions1 As New JigPromptPointOptions(vbLf & "Move:")
                    ' Set properties such as UseBasePoint and BasePoint of the prompt options object if necessary here.
                    prOptions1.UserInputControls = UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect
                    'prOptions1.UserInputControls = UserInputControls.GovernedByUCSDetect Or UserInputControls.UseBasePointElevation Or UserInputControls.Accept3dCoordinates
                    prOptions1.UseBasePoint = False
                    Dim prResult1 As PromptPointResult = prompts.AcquirePoint(prOptions1)
                    If prResult1.Status = PromptStatus.Cancel AndAlso prResult1.Status = PromptStatus.[Error] Then
                        Return SamplerStatus.Cancel
                    'If prResult1.Value.Equals(mLocation) Then
                    If Not mLocation.IsEqualTo(prResult1.Value, New Tolerance(0.000000001, 0.000000001)) Then
                        'Use better comparison method if necessary.
                        mLocation = prResult1.Value
                        Return SamplerStatus.OK
                    Else
                        Return SamplerStatus.NoChange
                Case 2
                    Dim prOptions2 As New JigPromptAngleOptions(vbLf & "Rotate:")
                    prOptions2.UseBasePoint = True
                    prOptions2.BasePoint = mLocation
                    prOptions2.UserInputControls = UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect
                    Dim prResult2 As PromptDoubleResult = prompts.AcquireAngle(prOptions2)
                    If prResult2.Status = PromptStatus.Cancel AndAlso prResult2.Status = PromptStatus.[Error] Then
                    If prResult2.Value.Equals(mAngle) Then
                    Else
                        mAngle = prResult2.Value
                Case 3
                    Dim prOptions3 As New JigPromptDistanceOptions(vbLf & "Scale:")
                    prOptions3.UseBasePoint = True
                    prOptions3.BasePoint = mLocation
                    prOptions3.UserInputControls = UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect
                    Dim prResult3 As PromptDoubleResult = prompts.AcquireDistance(prOptions3)
                    If prResult3.Status = PromptStatus.Cancel AndAlso prResult3.Status = PromptStatus.[Error] Then
                    If prResult3.Value.Equals(mScaleFactor) Then
                    Else
                        mScaleFactor = prResult3.Value
                Case Else
                    Exit Select
            End Select
        End Function
#End Region
#Region "Commnads"
        Public Sub Jig()
            Try
                If PrivateJig() Then
                    TransformEntities()
            Catch ex As System.Exception
                IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString)
            End Try
        Public Function PrivateJig() As Boolean
            Try
                Dim pr As PromptResult
                Do
                    pr = AcEditor.Drag(Me)
                    ' Keyword handling code
                    If pr.Status = PromptStatus.Keyword Then
                    Else
                        Me.mCurJigFactorIndex += 1
                Loop While (pr.Status <> PromptStatus.Cancel AndAlso pr.Status <> PromptStatus.[Error]) AndAlso Me.mCurJigFactorIndex <= Me.mTotalJigFactorCount
                If Me.mCurJigFactorIndex = Me.mTotalJigFactorCount + 1 Then
                    Return True
                Else
                    Return False
            Catch
                Return False
            End Try
        End Function
#End Region
#Region "Commands"
        <CommandMethod("TestMoveRotationScaleJig_Method")>
        Public Shared Sub TestMoveRotationScaleJig_Method()
            Dim Doc As Document = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = Doc.Database
            Dim ed As Editor = MgdAcApplication.DocumentManager.MdiActiveDocument.Editor
            If Not Doc.IsActive Then
            Try
                Dim selRes As PromptSelectionResult = ed.GetSelection()
                If selRes.Status <> PromptStatus.OK Then
                    Return
                Dim prOpt As New PromptPointOptions(vbLf & "Base point:")
                Dim pr As PromptPointResult = ed.GetPoint(prOpt)
                If pr.Status <> PromptStatus.OK Then
                    Return
                Dim jigger As New MoveRotationScaleJig(pr.Value)
                    For Each id As ObjectId In selRes.Value.GetObjectIds()
                        Dim ent As Entity = DirectCast(tr.GetObject(id, Teigha.DatabaseServices.OpenMode.ForWrite), Entity)
                        jigger.AddEntity(ent)
                    Next
                    'jigger.Jig()
                    tr.Commit()
                End Using
                ed.WriteMessage(ex.ToString())
            End Try
        Public Shared Sub MoveRotationScaleJig_Method(BasePoint As Point3d, Entities As List(Of ObjectId))
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Try
                Dim jigger As New MoveRotationScaleJig(BasePoint)
                    For Each id As ObjectId In Entities
                        Dim ent As Entity = DirectCast(tr.GetObject(id, teigha.DatabaseServices.OpenMode.ForWrite), Entity)
                    Next
                    'jigger.Jig()
                    tr.Commit()
                End Using
            End Try
#End Region
    End Class
Re: AcquirePoint
Posted: Wed Jun 16, 2021 7:50 am
by DenisSilveira
Code to create Pallete
 Private Sub LigaçõesToolStripMenuItem1_Click(sender As Object, e As EventArgs) Handles LigaçõesToolStripMenuItem1.Click
        Hide()
        CommandMethods.CreatePaletteLigacoes()
Re: AcquirePoint
Posted: Wed Jun 16, 2021 7:51 am
by DenisSilveira
Public Shared Sub CreatePaletteLigacoes()
        Dim ps As IntelliCAD.Windows.PaletteSet
        ' ps = New Intellicad.Windows.PaletteSet("My Palette")
        ps = New IntelliCAD.Windows.PaletteSet("Ligações", New System.Guid("F69E9148-2DF8-4911-8442-8C97AF23C2EE"))
        ps.Style = IntelliCAD.Windows.PaletteSetStyles.ShowPropertiesMenu Or
                     IntelliCAD.Windows.PaletteSetStyles.ShowAutoHideButton Or
                     IntelliCAD.Windows.PaletteSetStyles.ShowCloseButton
        'ps.Opacity = 90
        'ps.Size = New System.Drawing.Size(250, 400)
        ' ps.MinimumSize = New System.Drawing.Size(225, 400)
        '//ctrl.Dock = System.Windows.Forms.DockStyle.Fill
        Dim uc1 As New ucLigacoes
        Dim p1 As IntelliCAD.Windows.Palette = ps.Add("Ligações", uc1)
        '//You may Or may Not need the below code for list/combo boxes to retain focus.
        'ps.KeepFocus = True
        ps.Visible = True
Re: AcquirePoint
Posted: Mon Jun 21, 2021 7:49 am
Try to replace the Jig with this one:
        Public Function Jig() As Boolean
            Try
                Do
                    Else
                    Return True
                Else
                    Return False
            Catch
                Return False
            End Try
        End Function
and the command method:
        <CommandMethod("TestMoveRotationScaleJig")>
            Dim ed As Editor = CadApp.DocumentManager.MdiActiveDocument.Editor
            Try
                    Return
                    Return
                        Dim ent As Entity = DirectCast(tr.GetObject(id, OpenMode.ForWrite), Entity)
                    Next
                    If jigger.Jig() Then
                        jigger.TransformEntities()
                    tr.Commit()
                End Using
            End Try
Re: AcquirePoint
Posted: Mon Jun 21, 2021 6:45 pm
by DenisSilveira
Still same result ... unfortunately.
I saw your ScreenShot thousands of times ...
Here my ScreenShot:
https://drive.google.com/file/d/1aTQTMa ... sp=sharing
Check it out !!
Re: AcquirePoint
Posted: Tue Jun 22, 2021 9:27 pm
Sorry, I cannot access your screen shoot.
Re: AcquirePoint
Posted: Tue Jun 22, 2021 9:50 pm
by DenisSilveira
